Author Topic: 72 750 squeaky front brake, also binds when front wheel turned  (Read 959 times)
Offline kschwarz
« on: November 08, 2008, 01:19:56 PM »
Hi all
Returning member#103.  OK I've read the FAQs, put in new brake shoes, a new caliber piston (pricey), new oring, and cleaned the groove and flushed ad nauseum.  Opened the
master cylinder and pressed the lever, a bubble comes out of the tiny hole.  After I got the new piston and oring, the bike worked fine, stopped well, even could see the disc showing a broad swath of clean metal where the pads touch.  Once again, the problem resurfaces.  The brake is extremely squeaky at slow speeds.  If the handle bar is turned when walking the bike out of the garage, the brake drags.  If the the handlebars are straight, no drag.  The noise is embarrassing, and relying on the rear brake is no fix.
any help appreciated
Thx
Ken
Offline fastbroshi
  • Puppet
Re: 72 750 squeaky front brake, also binds when front wheel turned
« Reply #1 on: November 08, 2008, 07:15:49 PM »
Ken,
   I had the same problem and didn't even realize it when I first got my bike (77 550), as I was concentrating on the motor.  It was always an effort to push it, and turning the bars made it worse.  When I rebuilt the caliper the only thing wrong that I found was somehow the nylon washer that presses up agains the pad on the piston side had gotten wedged between the piston and pad, probably cocking the piston or pad a bit, not sure which.  Either way, I had the above problem and the pad wasn't contacting the rotor on center.  New nylon washer, put back together, bled the system, now it works like a charm.
  I've never worked on a 750's brakes, but maybe this is your prob too.
Just call me Timmaaaaay!!!
Offline fergie
« Reply #2 on: November 08, 2008, 09:00:09 PM »
I had a squeaky brake after installing new pads on my 78 550. all I ended up doing was putting a product on the back of the pads that is designed to stop brake noise. avaliable at your local auto store.
The most interesting man in the world
Offline coyotecowboy
  • Easily Distracted
    • American Legion Riders Post 69 Medicine Lodge, Ks
« Reply #3 on: November 08, 2008, 09:05:06 PM »
Are your forks in the triple trees straight?  If its hanging up when you turn the bars then you better broaden your search.  I could see it if a drum brake and cable was involved, but not on disc brakes.  I'm assuming that your axle caps are on the right direction and the bolts are tight.  Fork brace or not?  Man, could be any number of things ???
The adventure begins when things stop going as planned - Glen Heggstad
http://www.alrpost69.com/
Sunrise Orange 750 K2
1981 Husqvarna 430 XC, "Inga"
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #4 on: November 08, 2008, 09:27:25 PM »
Not to be dumb, but is the brake hose routed correctly? I erred when I was first working on my front brake and routed it wrong and when turning the steering to the left, it would "auto-apply" the front brake slightly.
I'm sure you already checked that, but just thought I would mention it just in case.
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
Offline Really?
« Reply #5 on: November 08, 2008, 10:01:05 PM »
The last two sound very plausible to me.  Pinched brake line or forks twisting.  As odd as it sounds.  Maybe the mounting of the caliper is loose and it cocks a bit.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
