Author Topic: left hand control wiring question.  (Read 1022 times)
Offline cafe2be
« on: November 08, 2008, 03:24:02 pm »
I want to remove the left hand controls. Can I simply unplug the harness and everything will continue to work? Also what is the wiring coming from the clutch lever??
I imagine once the control is remove there will only be a low headlight. This can be resolved by running slightly higher wattage bulb with a fuse?
It is my mission to clean the bars as much as possible:
So far, key and start button under the seat.
gsxr mc
2.5" gauges
toggle switch on the bucket for run/kill
idiot lights replaced with 3 small leds
Offline cafe2be
Re: left hand control wiring question.
« Reply #1 on: November 09, 2008, 06:43:31 am »
anyone?
Offline NickC
« Reply #2 on: November 09, 2008, 08:22:34 am »
What bike? What do you have on the left side at the moment? Turn,horn, dimmer?
You can't just unplug it and everything work, you will have to do some rewiring in harness. Do you plan on having turn signals?
Offline cafe2be
« Reply #3 on: November 09, 2008, 05:42:21 pm »
running headlight, no horn, no turn signals. The bike is a 77 750f. I just plan to unplug, not remove completely, incase I want to reinstall.
Offline Kevin D
  • SE Michigan
« Reply #4 on: November 09, 2008, 06:17:12 pm »
I found the wiring diagram in the library:
http://sohc4.com/tiki-list_file_gallery.php?find=&galleryId=9&offset=20&sort_mode=created_desc
2 wires at clutch lever?? green, green/red??
Looks like it provides a ground connection for the starter relay. A safety switch. So you don't start the bike in gear without pulling in the clutch lever. If you just disconnect, you'll have to go to neutral to use the starter. If you tie 'em together you'll have to use your noggin, and pull in the clutch, before you use the starter. :)
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline cafe2be
« Reply #5 on: November 09, 2008, 06:34:38 pm »
So I guess, just disconnect, the horn, signals and headlight wires and I will be fine.
As for the clutch lever, I will just leave it or always start the bike in Nuetral.
