Author Topic: November 8th 2008 Hard Cider  (Read 1008 times)
Offline UnCrash
  • Pass
    • My Blog
« on: November 08, 2008, 07:27:00 PM »
Below is my recipie and initial readings for this years hard cider.   My first attempt at culturing wild apple yeast up enough to get a good initial fermentation.  Additionally I'm not using any sugar this year.  I boied down 4 gallons of cider to 3/4 of a gallon and added that back.  I should have a final alcohol percentage just above 7.
Previous years I've used Champagne yeast and have had very mixed results with the cider ending up too wine like...
Cider is a slow process so my progress reports won't come very often....
My fingers are crossed and all signs are good.
October 28th 1 gallon unpasteurized cider purchased from Thompson’s Orchard
   Gallon sits unopened in refrigerator until the morning of Nov. 8th.
Half gallon yeast starter made:
A little more than the top half of the Thompson’s unpasteurized gallon is boiled down to syrup.   The remainder of the bottom of the gallon is put in a 1 gallon glass bottle.  The apple syrup is added back along with 1 tsp yeast nutrient, and air-lock put on bottle.
Within 30 minutes fermentation is noticeable.   Airlock bubbles increase throughout the day to a rate of 1 every 7 seconds.
6 gallon batch prepared:
4 gallons UV treated Thompson’s cider boiled down to ¾ of a gallon, this is then poured into the carboy
5 gallons cider poured into carboy – first ½ of the gallon poured from high, then lid screwed on and gallon shaken vigorously to aerate.  Remainder is then added to carboy.
OG = 1.060
Potential Alcohol = 7.5%
½ gallon yeast starter pitched
Offline 333
  • Time for change
Re: November 8th 2008 Hard Cider
« Reply #1 on: November 08, 2008, 08:18:54 PM »
I'll be interested in the final product, and how it tastes.  Is it like cider, but with a kick?  Or is it like some of the "ciders" available in stores?
It does sound like a lot of work, compared to my Dad's recipe.  His was just a gallon(unpasteurized), a pound of sugar, and a pound of raisins.  Keep in a cool dark place.  After about 30 days, strain off any solids(raisins) and keep it cool and dark.  He used a clay jug like what would be used in a jug band(? Best description I can think of).  In time, I think the alcohol level was on par with hard liquor.  He was diabetic, so he didn't imbibe too often, but every now and then, he'd go downstairs with a paper cup, and come back upstairs giggling.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline UnCrash
  • Pass
    • My Blog
« Reply #2 on: November 08, 2008, 08:27:06 PM »
This should come out like a much stronger version of the storebought hard cider.
The raisins give cider a wine like quality and the fruit esters would have made the alcohol content taste a little higher than it was.  I've done similar batches and ended up with a final product with about 10% alcohol.
It does have a kick, and will put a smile on your face : )
What really turns the notch up a little is to take the cider outside on a really cold  late winter day and let the water freeze.  Scoop off water all day until you end up with a slurry that doesn't want to freeze. Now you're talking ICED CIDER!   Watch out, it will make you act stupid in a real hurry. ;D ;D ;D
« Reply #3 on: November 08, 2008, 09:07:14 PM »
HA..HA  !!...I am drinkng 7% allpe cyder as i tyipe...... ;D
Offline tramp
« Reply #4 on: November 09, 2008, 03:20:03 AM »
glad to see it's not having any effect
1974 750k
Offline Dusthawk
  • Dusthawk & Rita IFO Phils Cafe, bestest Breakfast!
    • My MySpace Place
« Reply #5 on: November 11, 2008, 06:34:57 AM »
Have you ever tried using a Mead yeast? Once we switched from champagne yeast to Mead yeast, our Meads started coming out much better and some even resulted in slight carbonation. Also, consider using a Jack LaLanne juicer and adding a couple of teaspoons of honey to keep it from going vinegar.
1971 Honda CB750 K1 Chopper A.K.A. Rita
Build Thread: http://forums.sohc4.net/index.php?topic=86383.25
