Author Topic: POR15 what is this stuff?  (Read 1157 times)
Offline Hush
« on: November 09, 2008, 02:43:03 am »
This box of stuff came with the 79 650 I got earlier in the year, never bothered to open it as I had a good tank and wasn't thinking of doing a skin job inside the tank anyway.
I've heard so many horror stories about these going wrong!
But I digress, today I'm looking for something to clean out my 82 Custom tank which is full of unmentionable (possibly radioactive) crud and I remember this box of goodies.
According to the label the contents are: 1 Litre Marine Clean, 250ml Fuel Tank Sealer, Ilitre Metal Ready, Detailed instructions.
OK so the sealer is missing and the detailed instructions are AWOL too but inside is 2 bottles of interesting products that could be perfect for cleaning my tank out.
Question: how do I use these products, I am not putting a new skin inside my tank, I just want to clean/de-rust the tank.
Offline Bob Wessner
  • "Carbs Suck!"
Re: POR15 what is this stuff?
« Reply #1 on: November 09, 2008, 03:11:15 am »
This might help. I used only steps one and two on mine several years ago and it's still fine. Good luck.
http://www.networksplus.net/n0nb/repairs/por15intro.html
« Reply #2 on: November 09, 2008, 04:48:26 am »
Firm in UK called Frost sell this stuff and if they put their name to it it has to be good, aint used it myself but i;m sure they have a web site where you can get destructions
Offline jtb
  • An unlikely
« Reply #3 on: November 09, 2008, 07:25:09 am »
Mine developed a pin hole leak near the petcock a couple of years ago and I bought a POR-15 kit.  It included a strip of fabric for just such problems.  I sanded the area around the hole to bare metal, and used the fabric with JB Weld to patch the exterior (it was on the bottom) and then cleaned the interior per directions, and went ahead and used the liner too.  It worked great, and I haven't had a problem since.
1977 CB750F
1985 V65 Sabre
Offline springer
  • They call me Stubby
« Reply #4 on: November 09, 2008, 07:55:45 am »
http://www.por15.com/
i have use there paints and good stuff
                                               springer
1975 cb55f
1977 cb550k
2007 suzuki gsx1300r Just a Speed Toy
and as of 1/2014 sold
Offline CBJoe
« Reply #5 on: November 09, 2008, 08:02:27 am »
I'm sure someone will chime in if i'm wrong, but I believe that you have to re-cote the tank if you are at the point of using chemicals to clean it out.  Whatever rust-resistance that the tank once had is completely gone at this point and your cleaning might be all for naught after a short time.  Especially if the rust/buildup was really bad, because the metal at the bottom of the tank is that much thinner.
Cheers...Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline Hush
« Reply #6 on: November 10, 2008, 11:36:09 pm »
Cheers Bob, that is a damn good reference site.
