Author Topic: fuel in the airbox boot  (Read 805 times)
Offline uwjberg
« on: November 09, 2008, 11:28:33 am »
ok - so i got my bike running this morning, set the idle, and everything was running great. after 15 minutes or so of idle and tuning, the overflow tubes belched out a bit of gas, then stopped. it did this a couple of times.
i turned the bike off, and started working on something else. several minutes later, i saw gas leaking out of the boot between the carb and the airbox. when i removed the airbox, there was a small puddle in the carb on the airbox side.
what could be causing this? is it the float level? anything else i should check?
Offline wrenchmuch
Re: fuel in the airbox boot
« Reply #1 on: November 09, 2008, 11:36:44 am »
Sounds like you've got dirt in you float needle valves or they are old and not sealing properly anymore .
CB750K1
CB750K4
Offline scunny
  • don't call me expert
« Reply #2 on: November 09, 2008, 11:37:34 am »
 yep, it's your floats. if the carbs have been dry for a while a float can hang up, give it a tap and it should stop. and always turn your petcock off. otherwise you will have to pull the carbs
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
KingCustomCycles.com
« Reply #3 on: November 09, 2008, 12:51:23 pm »
Fuel flows into the airbox and boots out of the top of the bowl because the drain line hole is smaller than the inlet around the needle.  Lots of fuel in, only some can get out.  You may have clogged or restricted drain lines and tubes also.
