Logo merchandise is available at the SOHC/4 Shop
rear 500 uses 1 x 6304 and 1 x 6305rear 750 uses 2 x 6304 and 1 x 6305front both use 2 x 6302So yes they use the same bearings but in different quantities so the wheel spindles should be same diameter meaning from that point they should fit.THIS IS FOR 750 WIRE WHEELS
The 500 / 550 rear hubs use 2 wheel bearings: 1 x #6302 (15x42x13) and 1 x #6304 (20x52x15).The 750 uses 3 bearings: 2 x #6304 (20x52x15) and 1 x #6305 (25x62x17).
