Author Topic: Possible Clutch Issue...  (Read 678 times)
Offline sparty
  • I just play one on TV
    • Gallery
« on: November 10, 2008, 07:25:59 pm »
Yesterday I took the Hot Rod for a spin.  It was damn cold outside and I let the bike warm up before starting out.  My clutch was slipping pulling out into the roadway and then again at the next stop sign.  The slipping was gone by the time I returned home, but then again, I wasn't really letting out the clutch from a dead stop.  Is this typical in cold weather, or may I need an adjustment?  This was the first time I experienced a slip with this bike's clutch.
Sparty
1972 CB750 K2 Cafe' Style
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
Re: Possible Clutch Issue...
« Reply #1 on: November 10, 2008, 08:49:18 pm »
Slippage in cold weather is related to your oil viscosity.  Multi-weight oils with a wide viscosity range (e.g. 5W40) tend to be especially sensitive.
