Author Topic: Welding Noob questions  (Read 3909 times)
Offline Tim in Ohio
  • So I got that goin' for me, which is nice.
« on: November 11, 2008, 09:58:17 PM »
I am interested in some input from you guys who do fabrication/welding for their bikes.  I want to add this skill to my repertoire.  I am thinking that mig welding (GMAW) is the most appropriate type for a home hobbyist?  What are some recommendations on what I should look for in a welder?  How much should I expect to pay (good deal) on eBay or Craigslist?
1973 Honda CB350  Four
Check out my CB350F resto project...  watch a complete moron build a bike in front of your very eyes!: http://forums.sohc4.net/index.php?topic=38903.0
Re: Welding Noob questions
« Reply #1 on: November 11, 2008, 10:21:07 PM »
make sure it runs on 115 (unless you have 220v in your garage, then you can get a big one),
around 20 or 30 amps (don't want to be poppin breakers ya know)
you always get what you pay for
welders break (no mater what brand) and they have consumable parts, make sure you can find them (tips,nozzles,insulators,wire)
defiantly check ebay and CL a good one is not cheap (well, new anyway)
miller , hobart, lincoln electric, esab .some of the major names..  search away
http://www.millerwelds.com/products/mig/millermatic_140/
« Last Edit: November 11, 2008, 10:31:27 PM by spikeybike »
Offline my78k
« Reply #2 on: December 30, 2008, 07:26:11 AM »
Giving this one a bump as I too am looking to try out welding. While Spikey's opinion is ALWAYS valued I was just wondering if anyone else cared to add anything. Also, I know this limits my target audience to Canadians but wondering of anyone has had experience with Mastercraft products (Canadian Tire)?
Thanks in advance,
Dennis
Offline ElCheapo
    • Anubis Cycle
« Reply #3 on: December 30, 2008, 08:38:25 AM »
Because you are admittedly a "Noob" to welding I would highly advise that you get an auto darkening helmet. Get the best that your money will buy at the time. This will be your most used tool and will protect eyes which are not exactly replaceable ~ at least until we can sell body parts on Ebay. The cheaper auto dark helmets work fine, but the pricer ones work so much nicer.
1. You are going to want a gas shielded welder. I say this as they are more affordable than Heli-arch, however Heli-arch kicks just about anythings but in weld quality and ease of use.
2. You are going to want a 220 welder. This is because the 110 welders tend to put out cold welds when welding anything over 1/16". 220 means that you will need to have a 50 amp 220 circuit set up in your work place by someone who actually knows what the heck they are doing. I say 50 amp because as you run these 220 welder out of their duty cycle they tend to pull more amps. You don't want the welder dying mid weld. When pricing a welder know its "duty cycle" and know how long your longest weld will be. You want to stay within the duty cycle at all times. Newer 220 welders don't really have a duty cycle as all of the components are beefed up.
3. You can use a 220 stick welder, but this will require planning on your part when you start the weld so you can complete it. And the technique is much different than wire welding as you will be pushing the rod back at the puddle unlike wire where the puddle chases the electrode. Also rods are best kept in a toaster oven just prior to use. If there is the smallest amount of moisture in the flux the weld will spit and spatter.
4. Get a book on welding as I could go on for pages on what rods or wire to use for what and what precautions to take. This is something that you will have to learn through a reliable text source. There are several small welders handbooks out there that are about 15-20 years out of print in second hand book stores, however the material is still relevant. These will show you all of the types of welds from fillet to butt.
5. Your first weld project should be a welding table. Make the top at least 5/16 thick. This bugger will be heavy so you will want to put it on wheels, preferably pneumatic dolly wheels that will help keep the swearing to a minimum when moving it mid project. Make sure at least 2 of the casters are lockable because the first time it walks away when you are welding you will use up all of your swear words in a few seconds.
Hope this blather helps...... Feel free to message me if you have other questions.
And by all means people if I was wrong in this post somewhere please do point it out as I hate it when disinformation floats around the web, especially when it is expensive disinformation.
Contact me for affordable rotor drilling services at $55 each rotor. Same day service on CB750/CB500/CB550 rotors. Next day on everything else.
« Reply #4 on: December 30, 2008, 10:54:24 AM »
absolutely right, once you get a good one you will never go back
i disagree.   110 welders work great ,way past 1/16"  ...my millermatic130 gets full penetration on 1/4" plate(beveled of coarse)   i would guess that "noobs" are wanting to weld there bikes,  there isn't a single piece of metal on "any" bike thicker than that
for sure read books about it, but better then that would be to just practice ,  and remember the hardest part of welding is setting up the welder, not actually welding
and do your self a favor    ...don't learn to weld with flux-core,  learn that after you can do it with gas
Offline ElCheapo
    • Anubis Cycle
« Reply #5 on: December 30, 2008, 11:14:00 AM »
Millermatic? That'll each me to buy garbage like Lincoln. :)
I suppose you do get what you pay for..............? I guess my HomeDepot Lincoln 110 wire does 1/8 or better, but it is not pretty. Wish it was at least gas shielded. The welds I did on my lawntractor plow are still holding even after a beating. ::)
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #6 on: December 30, 2008, 12:11:36 PM »
I went and purchased one of those $100.00 / 110Volt mig welders found at Harbor Frieght and the likes. Started using it on light stuff. My thoughts were pretty much this thing is useless, except maybe for tin foil. ( Keep in mind I have little or no welding experience).
Then I took the unit to a guy who knows how to weld. He promptly demonstrated this thing to be a very excellent home hobbiest welder. It will indeed weld up to 1/4 in. with the prettiest sold weld you will find. So I get a few lessons.
I don't fool myself into thinking I'm a welder. I'm not. Nor do I think this $100.00 / 110 Volt unit is adequate for welding frames and the like, however this cheap welder has opened new doors and possibilities for me that I never had before. It works marvelously and does exactly what I need it to do. You can't go wrong for the price. If you have no welding skills find someone who does to give some tips.
My welds still aren't pretty, but they are solid, for the types of mods I do with light metals, it's perfect.
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
KingCustomCycles.com
« Reply #7 on: December 30, 2008, 12:23:09 PM »
I have a Lincoln 110 Weld Pac 3200 wire welder with argon/co mix in the bottle.  I weld Honda frames with this and do tab attachment and exhaust mods.  I could not be happier with the set-up.  I have done countless hours of welding on 6 frames and have yet to break or wear out anything on the machine.  I can now weld with this set-up creating welds like I can imagine in my mind.  Always before the imagined weld was far superior to the actual weld.  That is not the case anymore.  No smoke, no slag, and no popping.  I also got an 89.00 auto darkening helmet that is better than sex.  I guess I have around $700 in the whole business including spare wire, gas bottle and such.  I LOVE IT!
Offline scartail
« Reply #8 on: December 30, 2008, 12:30:54 PM »
Thumbs up on the auto-darkening helmet... I got mind from Harbor Freight for 50$. I think it is pretty good. Then again, I have had no experience with any other.
Regarding the welder, I have a Lincoln weldpak 100. It runs off of 110v, and supposedly does well for up to 1/4" using fluxcore. Since, I only tool around, and really don't do anything major, just exhuast work, frame bracing, sheet metal stuff, etc... It has been pretty good. I also have the MIG conversion for it, which I don't use much. I find that the fluxcore wire is most practical for my use. The only problem I have found with the fluxcore is the need to remove the slag completely when needing water/oil/air tight welds. I'm still learning.
I got it used for 200$, which came with a cart, the mig conversion kit, and a few tidbits. I think I got a really good deal on it.
'89 Hawk GT, newly acquired, daily beater...
'76 CB550, was my daily beater... my cafe project...
'72 Yamaha R5, newly acquired project... donated to my buddy...
'67 Suzuki T20, still working on her too... Currently in pieces...
Offline Zig
« Reply #9 on: December 30, 2008, 01:40:20 PM »
c10 with hard wire.
c25 with fluxcore.
220 volt ( better to have it and not need it than vice versa). Good machines detect voltage and will run on what you feed it but 220 is best. will burn .025 and .030 wire.
good machine is about 600 can, make sure has a gas kit. flw meter, fittings etc.
auto sheild? yes, but adjustable shades,9 thru 11. no control knobs on outside of sheild, they get busted.
keep your whip straight, bends cause wire to bind in liner and also restrict gas flow.
parts to be welded need to be clean!
careful about fans and open doors. will blow away your gas sheild.
tack your parts well before you weld it and remember your tacks will misalign (tacks contract as they cool) your work, plan for it.
on small work use a file to clean up, not a grinder.
Offline XN
« Reply #10 on: December 30, 2008, 05:36:52 PM »
My wife got me a Clarke 110v mig last year for my birthday. While not my first choice in a welder, I decided to not hurt her feelings and keep it. I must say the more welding I do the better I get. And over all its not a bad little machine at all. If your going to teach yourself I found using shielding gas was much easier and gave me a better weld over flux core. + its just so much cleaner. My first project was frenching in my license plate on my VTX...
78 Honda CB750K
02 Yamaha V-star 650
02 Honda VTX 1800
fuzzybutt
« Reply #11 on: December 30, 2008, 07:33:44 PM »
i have a lincoln sp 140t, great welder, all I, as a home hobbyist will ever need. welds either gas sheilded or with a simple, tool free polarity change, flux core.
Offline my78k
« Reply #12 on: December 30, 2008, 08:10:54 PM »
Guys, as always I can't thank you enough! I am far from being ready to take the plunge and will likely have a ton more questions! I am pretty sure I will bite the bullet and buy one but I need to to do a little more thinking first....I don't want to outgrow it too quickly after all (kinda like starting out on a Ninja 250 when we all think we need a Busa to get where we need to go  ;) )
I am thinking the Lincoln 140 is the likely culprit. They are currently around 6 bills at Canadian tire but I suspect I can grab it when it goes on sale...
As for college course I did some digging today and the loacal wants almost 600 just to signup plus the text book!!!! I picked up a clymer manulal for 25 and have book marked a few sites that are free  ;)
Keep the info coming please....not sure if this has been brought up to the mods but is there any interest in a welding specific forum on here???
Dennis
Offline cb350f-mark
« Reply #13 on: December 31, 2008, 10:22:31 AM »
Dennis, I'm also thinking of trying my hand at welding.  I was surfing for some introductory welding education near Toronto and found a 6 hour Saturday MIG course at Centennial for $185.
Mark.
Offline my78k
« Reply #14 on: December 31, 2008, 02:55:48 PM »
Thanks Mark! I was looking at Durham and they had that one that was 600 but it was s much longer course and went into other types of welding as well but for now I think the Mig will be enough for me. I have no plans to weld frames or anything but I do have some ideas for some mods to my tent trailer (luggage or wood rack) and my dad's utility trailer could also use some sections replaced.
Dennis
Offline Jim F
  • go baby go
« Reply #15 on: December 31, 2008, 08:58:20 PM »
All of my stuff is Miller
I have a syncrowave 250
an Inteletig system with a Maxstar 150 power supply
and of course  my Laser system
check it out
www.jmfmicroweld.com
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
« Reply #16 on: December 31, 2008, 10:54:29 PM »
wooooow .
i
want
a
laser :o :o :o
man those are some seriously tiny welds,  my hat is off to you,
 ...and here i thought tig was cool .. :D
Offline XN
« Reply #17 on: January 01, 2009, 11:00:18 AM »
I wish I could show you guys the laser welding we do at my work, but its classified... None the less its pretty bad A$$ Some of our weld beads are around 1/16 wide.
78 Honda CB750K
02 Honda VTX 1800
Offline 1timduke
  • '75 CB550
« Reply #18 on: January 01, 2009, 11:46:54 AM »
     Few things to make sure, if no one has mentioned it yet...Safety First!!!   Make sure you weld away from flammables in your garage or wherever, gasoline fumes accumulate near the floor and you might not smell 'em.   Shop rags, cans of brake and carb cleaner, all that stuff will go up when you don't need it to.   Welding fumes can also be hazardous (less so with MIG or TIG process) so a small fan may be necessary.   Careful though, too much wind can blow away your shielding gas.
     When you get your machine and start practicing, it probably wouldn't hurt to practice on something slightly thicker than bike frame, maybe 3/16" or so.   Learning how to weld on really thin stuff can be frustrating.
     And lastly, don't let anyone watch you weld without a hood!   I know a guy who's son watched him weld for several minutes unnoticed in his garage before he (the kid) said something.   Poor kid had the most horrible flash burn a few hours later :'( :'( :'(   If it ever happens to you or anyone near you, there's not too much that can be done.   It feels like sand in your eyes that you can't get out, only much worse, lasts for hours.
     There's plenty of great resources and classes out there, and I'm sure you'll get the hang of it after some practice.   Keep us posted.   Good Luck!   -Tim
The only thing I miss about the South is Waffle House!
« Reply #19 on: January 01, 2009, 12:45:38 PM »
yes yes yes oooh yes flash burn .....  not fun  :-[
fuzzybutt
« Reply #20 on: January 01, 2009, 12:51:58 PM »
i learned to weld by going out and getting a cheap little 99 dollar flux welder. i have access to scrap steel and i just welded and welded and welded until i could get a good looking weld every time. i'm still learning to weld really thin stuff but i'm getting there. i just fabbed and welded up filler panels for a friends tailgate and door handles on his mini truck.
Offline fishman_Phil
« Reply #21 on: January 01, 2009, 12:54:52 PM »
I have had a mig welder sitting in the garage for a couple of years now not being used but wanting to use it. Arc and oxy/acet was no problem to me, but could not get the Mig right so walked away. Yet, I was told by many that once you start using mig you will not want to go back to arc and gas.
My son was visiting the other day and he is a TIG and MIG welder and got him to give me some tips before he left for home. I had been trying to use the mig with flux/core with no great success and had gone and purchased some more wire and a gas bottle.
He instantly took off the flux/core wire and put on my other reel, hooked up the gas, tweaked the speed and current and was running these nice runs of weld on 1/16 plate. Straight away I saw my problem. I was drawing away from the weld with the hand piece like I would with an arc welder.
I tryed as he did, pushing from the weld, and bingo. Sweet as. Now to get some more practice on other stuff. He did explain though that for vertical down I would be drawing away. Cheers ...
1972 Honda CB350F (2); 1975 CB400F; 1983 CBX400F (1); 1962 Suzuki MA50 (1); Suzuki M15 (3); Suzuki M15Mk2 (2); Suzuki M31 (2); 1936 James H12 (2); 1948 Triumph Speed Twin 500; 1989 Suzuki GSXR250F; Yamaha Chappy (2); alot of work yet to be done.
Offline ghost
  • what do you mean i can't do that? I just did it didn't i
  • it's all about the last inch baby(even when it's metric)
« Reply #22 on: January 01, 2009, 03:28:00 PM »
practice is the best way to learn. an old weldes told me when i first started welding that it takes about a mile befor you start getting good, that was about ten years ago. in addition to a good autodim helmet, get a good welding jacket(mine is a tillman onyx comfortable, black, and it works nicely as a riding jacket) and don't weld in shorts and sneakers(ask me why)
1980 cb650c first bike i owned now the wife's ride.           1982 xv920j virago, bike i learned to ride on rescued it from a 13 year coma (sitting in the shed) now she runs beautifully and rides like a dream.
Offline bradj
« Reply #23 on: January 01, 2009, 09:18:50 PM »
I am a union boilermaker I stick weld for hours a day there is no reason to use a stick on a bike frame it WAY to much heat even if you use 3/32 rod you will still warp everything to #$%* a 110 gas mig is all you need go to a welding supply store and ask the sales person what they recomend and get a good helmet it sucks to get flashed and hurts for days
and dont go get a welder and start welding on your frame get some scrap steel and play around the heat and wire speed till your comfortable with the results have fun bradj
Offline Tim in Ohio
« Reply #24 on: February 14, 2009, 11:33:21 AM »
I did end up getting a Lincoln 110v mig welder.  Funny thing about my local welding shop advice... THEY said that for welding frames, a 220 tig machine is a must.  Spikey said they were full of [dung]...  I trust Spikey's opinion.  ;)
