Author Topic: carb from 550 to 750  (Read 1046 times)
chopper550
« on: November 13, 2008, 07:10:13 AM »
can you put a set of 750 carbs onto a 550 engine without much trouble
Offline Soos
Re: carb from 550 to 750
« Reply #1 on: November 13, 2008, 07:54:02 AM »
I'm quite sure there are a few threads on this subject...
Just repeat after me:
Theres no place like the search engine,
And go forth in search of mods......
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
chopper550
« Reply #2 on: November 13, 2008, 08:10:25 AM »
mmmmmmmmmmmmmmmm well i would have used it as i allways do but for some unknown reason it just timed out when i used it...never mind ill find some info someware thanks anyway
Offline texaninseattle
  • lots of protein in my
  • OHH Canada
« Reply #3 on: November 13, 2008, 08:31:53 AM »
I hate it when people just say use the search engine ....if thats the case then why not just lock the whole forum and just make it searchable only
1978 Cb550k(Sold)
emgo pods
mac 4-1
105 mains
stock pilots
needles set 1 step richer than stock
IMS 2 turns out
1982 Suzuki GS850g
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #4 on: November 13, 2008, 08:34:02 AM »
Sometimes we cranky old farts, just need to sound superior. ;D
FJ
Offline bender01
« Reply #5 on: November 13, 2008, 08:39:18 AM »
Id think the rack would be to wide for starters from the 750.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #6 on: November 13, 2008, 08:43:44 AM »
It's doable, it just takes some imagination to make the intake rubbers. I have a friend that did it on his 550 race bike, and it made an appreciable difference. He used radiator hose if I remember right, and played with the lengths until he was happy...
Hope this helps!
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
chopper550
« Reply #7 on: November 13, 2008, 08:49:12 AM »
Well thanks guys very helpfull indeed.......i just wasnt 100% sure if they would fit......... opps did you use the seach engine for that info......lol......im old school been building chops for 30 years mainly triumph bsa ect never realy work on jap bikes but there we go i am now iv been offerd a set but like a 3 hour drive so just wanted to know if with a bit of modding would fit and run ok....thanks again........
Offline Soos
« Reply #8 on: November 13, 2008, 10:39:19 PM »
Yeah, yeah...
No offence, but you only have 16 posts... I was thinking you were new to here...
But anyways...
If 650 carbs will fit then so will the 750 carbs.(ask me how I know.....)
In fact here are 2 threads mentioning 750 carbs on a 550.
http://forums.sohc4.net/index.php?topic=17841.15
http://forums.sohc4.net/index.php?topic=12840.0
l8r
-=≡ Soos ≡=-
Offline svenD
« Reply #9 on: November 14, 2008, 06:37:49 AM »
chopper
am installing a rack from a K3 on my 77,and they fit right into the 550 boots,with some effot.spacing exactly tke same.go for it.
Offline Soos
« Reply #10 on: November 14, 2008, 06:41:56 AM »
check this thread, interesting reading....
http://forums.sohc4.net/index.php?topic=43161.msg448006#msg448006
l8r
-=≡ Soos ≡=-
Offline svenD
« Reply #11 on: November 14, 2008, 07:43:56 AM »
chopper
yes fairly easy,but not as easy as writing a check for a bigger bike!
Use the carb runners from the 77-78 550s.they make the job easyer,new carb boots too.
