If the airbox is off,you should be able to look into carbs and see the slides sitting down. If they are....I agree with everything that has been posted......synch is very important....vac leaks,timing. Just keep at it and you will be rewarded. If your slides aren't sitting down,you will have to do some investigating....carbs hanging up,throttle cables, etc. Have fun with it!!!!
