Author Topic: Valve Cover Removal  (Read 1356 times)
Offline Venturous
  • CB750 Hack Pilot
    • eMotorcycling
Valve Cover Removal
« on: November 14, 2008, 12:02:15 PM »
My bike has some aftermarket chrome valve covers. In the day, I suspect they looked sweet, but the chrome is now in sad shape. I am considering finding a stock cover and polishing.
My question is... do you have to remove the engine from the frame just to swap the valve covers, or can it be done on the bike?
Thanks..
« Last Edit: November 14, 2008, 03:06:20 PM by Venturous »
eMotorcycling
'72 CB750-K1 w/Spirit Eagle sidecar
'02 Royal Star Midnight Venture
Offline Soos
Re: Valvle Cover Removal
« Reply #1 on: November 14, 2008, 12:12:41 PM »
what year/model bike?
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline bunghole
« Reply #2 on: November 14, 2008, 12:16:42 PM »
If it is a 750, you'll have to pull the engine.
I wonder if it would be cheaper to strip the chrome from the existing cover and polish that.  I don't know if removing chrome is a big deal or not.  Anyone?
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline Venturous
  • CB750 Hack Pilot
    • eMotorcycling
« Reply #3 on: November 14, 2008, 12:19:35 PM »
It is a CB750 K1.
Rats... I was afraid of that. I ain't pulling the engine just for that. Have to wait until I have another reason for pulling the engine. Thanks!
eMotorcycling
Offline bunghole
« Reply #4 on: November 14, 2008, 12:30:47 PM »
I created (stole the idea) a bracket and sling device that makes it almost effortless to remove and reinstall the engine from my 750K.
http://forums.sohc4.net/index.php?topic=36812.msg442400#msg442400
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline Patrick
« Reply #5 on: November 14, 2008, 12:56:28 PM »
Stripping chrome is extremely difficult unless you are a chromer and not worth the expense of a decent used cover....
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline goon 1492
  • Sucka Repellant
« Reply #6 on: November 14, 2008, 01:02:58 PM »
I have heard of using easy off oven cleaner in the rc car forum I used to get into but have never tried it. I also did a little searching on it, (was inititally scared to type in chrome stripper, wasn't sure if I would get some naughty stuff :P) but I found this site seems like an interesting site.
http://www.nmfrc.org/crarchive/sep08a.cfm
Offline Kevin D
  • SE Michigan
« Reply #7 on: November 14, 2008, 01:39:43 PM »
Have you seen this kit?? It allows top end teardowns without engine removal:
http://forums.sohc4.net/index.php?topic=43143.0
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Venturous
  • CB750 Hack Pilot
    • eMotorcycling
« Reply #8 on: November 14, 2008, 03:08:30 PM »
Yes, I have. But pulling the engine seems easier to me than going through all that.
eMotorcycling
« Reply #9 on: November 14, 2008, 03:11:09 PM »
Oven cleaner attacks/dissolves aluminum.  It's ok on steel or plastic.
Offline Venturous
  • CB750 Hack Pilot
    • eMotorcycling
« Reply #10 on: November 14, 2008, 03:17:06 PM »
Hmm.. That does seem interesting and if that easy, it might be easier to clean and polish the engine with it out. But from your pictures, afraid I can't see enough to duplicate it. Do you recall what thread you learned how to make that? That could change my mind on pulling the engine..  ;)
eMotorcycling
Offline bunghole
Re: Valve Cover Removal
« Reply #11 on: November 14, 2008, 03:32:53 PM »
I'll see if I can find the original post.  I sort of took that idea and modified it to work with what I had access to.  I know that KingCustomCycles uses something similar:
http://www.kingcustomcycles.com/howitisdone.html
What I did was to take some steel flat stock and bend it into a C shape that would bend around the top tube of the frame.  I then reinforced that by welding some more stock to the sides to make it rigid.  On the bottom of the C, I bolted an engine width length of pipe.  On each end of the pipe, I used these to hold the engine:
http://www.amazon.com/Master-Lock-3060DAT-12-Foot-1-Inch/dp/B0009V1WXY/ref=sr_1_3?ie=UTF8&s=automotive&qid=1226705290&sr=8-3
Then I attached an eye bolt to the top of the C to attach to a chain hoist:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=996
A cheaper rope hoist would work just as well.  Just make sure all of the components are strong enough to hold up about 170 pounds.  I tested it by hanging from it.  I'm scientific like that.
With the engine supported in the sling from the hoist, I can maneuver the frame using my motorcycle jack:
http://www.sears.com/shc/s/p_10153_12605_00950190000P
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline bunghole
« Reply #12 on: November 14, 2008, 03:34:14 PM »
You can sort of make out the components in this pic:
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline gregimotis
  • poet laureate; SOHC4.
« Reply #13 on: November 14, 2008, 04:00:13 PM »
Pulling the engine takes a while the first time, but it isn't difficult (not to say that there bracket isn't sweet).  A couple hours of taking parts off and labeling / sorting them; you and a friend and twenty minutes to drag the engine out; do whatever work you intend and then the same to put it back in.  Half the time the second time around.
Take the opportunity to clean your engine all around get and all the nooks in your frame and the bike will look much nicer.  It's harder It's impossible to do as good a cleaning with the engine in frame.
Another trick I got somewhere on this site:
  stack up boards or bricks or old magazines under your engine before taking the mounts out.  Lean the bike over a bit to get one last piece of cardboard under it and now the engine is sitting on it's 'stand' as you remove mounts.  Much easier to get out and back in.
