Author Topic: 74 550K runs flat after 2000 RPMs  (Read 690 times)
Tattoo
« on: November 14, 2008, 03:55:27 PM »
   Hi, Ok it's better but it still runs flat after 2000 RPMs. I have a 74 550K I just built the carbs and sycrionized them. Someone had built them before and they were way off. I road it today and it's better but it's still flat after 2000 RPMs. It will still go faster but it takes a while. Any one run in to this before? Thanks Tattoo
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: 74 550K runs flat after 2000 RPMs
« Reply #1 on: November 14, 2008, 04:18:25 PM »
intake leak? timing? advance? points?
Can you tells more of what youve done to the bike?
No.
Tattoo
« Reply #2 on: November 14, 2008, 04:21:10 PM »
I just bought the bike. NO intake leak I checked with carb cleaner. I built the carbs. I haven't checked the points or timing. I guess that's next? Tattoo
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #3 on: November 14, 2008, 04:30:33 PM »
You need to do a complete tune-up and check up first.
you need:
new plugs
new oil
check points
check timing
adjust cam chain
check valve clearances
carb synch
THEN see how it goes.
No.
Tattoo
« Reply #4 on: November 14, 2008, 05:18:18 PM »
I'll do that tomorrow. Mnay thanks, Tattoo
« Reply #5 on: November 14, 2008, 06:35:25 PM »
You also need to tell us if the stock exhaust and air filter are being used.  And, if the air filter is new.
Tattoo
« Reply #6 on: November 14, 2008, 07:26:11 PM »
Yes I'm sure that would help. New filter with stock air box. 2 into 2 aftermarket exhaust. Tattoo
