Author Topic: "I held a screwdriver across the solonoid and she turned over... "  (Read 1513 times)
Quote was taken from OTTO's Thread on his sweet barn find.
What is this an indication of?
Still learning all these tricks to diagnosing problems, and wanting to sponge all the info i can.
Thanks guys!
Offline Otto
Re: "I held a screwdriver across the solonoid and she turned over... "
« Reply #1 on: November 17, 2008, 09:09:45 AM »
I used it as a test to determine that solonoid and battery would turn the motor over. Crossing the terminals with a screwdriver, removes the starter button fom the circuit in effect.
Bob
Otto
1971 HONDA CB750K1- Valley Green Metallic
2007 Triumph Bonneville - Silver/Black Carburetted
Offline voxonda
« Reply #2 on: November 17, 2008, 09:11:35 AM »
Correct, and so closes the circuit so the startermotor will turn over.
Offline 750K2
  • new rider with an old bike
« Reply #3 on: November 17, 2008, 09:41:23 AM »
but doesn't determine the condition of the solenoid...just jumps the circut using a conductor that can withstand the high current draw of the starter motor.
good luck!
« Reply #4 on: November 17, 2008, 09:52:31 AM »
So, if this is the only way to get the enging to crank, we've either got a bad starter, or a bad solenoid. Correct?
Thanks for the knowledge.
fb1
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #5 on: November 17, 2008, 10:07:21 AM »
Not quite.
If the engine cranks with this method, there's nothing wrong with the starter motor - you are effectively just connecting the battery to the starter motor (so don't do it for long - and use a big screwdriver!)
Next test is to short the input to the solenoid so as to replicate the action of the starter button. If the engine cranks then the button circuit is shagged. If the the motor doesn't crank, then the solenoid is the first port of call.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
