Author Topic: Painting the exhaust system  (Read 1712 times)
Offline Grosen
« on: November 17, 2008, 09:00:46 AM »
Hi
I bought a Honda CB 550F from 1975 two weeks ago and can't wait working on it. I have been reading a lot of threads in here, and thanks for a lot of great information
I have to paint the exhaust system as the chrome is in bad shape. What kind of black paint can i use for this? Is has to resist the high temperatures.
Thanks
Grosen
Offline tygrant
Re: Painting the exhaust system
« Reply #1 on: November 17, 2008, 09:04:08 AM »
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline Grosen
« Reply #2 on: November 17, 2008, 09:09:48 AM »
Thanks, i'll try the local hardware store...
Offline A Grove
  • Some people call me a
« Reply #3 on: November 17, 2008, 09:09:55 AM »
Go to walmart and take your pick.  Mine was made by duplicolor, has probly 7-8 hours of hard use on it and still hasn't started flaking, etc.  Plan to wrap things eventually.
« Reply #4 on: November 17, 2008, 09:23:14 AM »
I used some high-temp engine header paint to line the inside of the horn.  Found it at the local auto store. Covered up the area just fine. Be sure to prep the are well to be sure it adhears.
Offline A Grove
« Reply #5 on: November 17, 2008, 09:42:36 AM »
Forgot to mention that... I have a sandblaster in the basement, so I used that.  Prep is a big must, especially when trying to paint chrome.  Either sand it off, or get it blasted.  My advice.
Offline chrislib
« Reply #6 on: November 17, 2008, 09:50:13 AM »
I used the cheap-o BBQ from the depot,lowes etc. IIRC it was like 6 bucks or so for the can. The key is the prep, scuff the surface very well and get it grease free. I then used a propane torch to pre-heat the tubes and sprayed on several light coats.I did not prep mine as well as I could have because I was planning on using wrap, I have since decided that I like the look of just the paint, that said  it has held up surprisingly well over the summers riding but I may re-do it over the winter.
Chris...closet Idlefiddler
#1975
1973 CB750K...CANDY BACCHUS OLIVE
Offline cafe2be
« Reply #7 on: November 17, 2008, 10:34:08 AM »
Chrislib, this is the method for painting over chrome? It held that long, Hell I am going to try this over the winter then.
« Reply #8 on: November 17, 2008, 02:18:28 PM »
For a paint to properly bond to a chromed surface, the surface needs to be prepped (sanded, scuffed, blasted, etc.) to a water break free condition, and then cleaned with an alcohol solvent to be free of contaminants.  any contaminants will create a weak bond, and may cause flaking after many cycles of cold to hot to cold, etc.
below is an article, for a different hobby of mine, but it describes obtaining a water break free surface to get a good surface bond and prevent any flaking or cracking. Easily applied to painting over chrome.
For chrome, use heavy steel wool or sand blasting, as stated above, to knock down the surface sheen.
http://www.rodbuilding.org/library/waterfree.html
Offline A Grove
« Reply #9 on: November 17, 2008, 04:29:37 PM »
Not only does sand/media blasting get rid of the "sheen" and "scuff" up the surface, but it actually eliminates the chrome all together.  Hence fifteen or so years from now when the chrome starts to "flake" (depending on the quality of chrome), the paint wont come with it.
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #10 on: November 17, 2008, 05:47:04 PM »
scuff up those old chrome pipes with some Scotchbrite pads and then hit it with some DEI High Temp ceramic header paint. I have had great results with the black, red and white, and you can find it at Advance Auto Parts, Pep Boys, etc.  I found that regular engine/high temp paints do not hold up as well as this "ceramic" stuff.
Offline Grosen
« Reply #11 on: November 18, 2008, 08:35:45 AM »
Thanks for all the tips. Would any of you, who have already done this have a picture you could upload? Just to get an idea of the finish.
Thanks.
Offline A Grove
« Reply #12 on: November 18, 2008, 09:00:56 AM »
from this:
to this:
overall... I dig it blacked out better.
Offline chrislib
« Reply #13 on: November 18, 2008, 05:42:30 PM »
Thanks.
you can see right where the pipes bend down that the paint is flaking a bit. This pic was taken in July-ish, it has`nt gotten any worse but its still not optimal. Had I done a proper prep I`m confident it would not have flaked.
#1975
Offline Grosen
« Reply #14 on: November 18, 2008, 05:47:20 PM »
Thanks for the pictures. I really like the finish on the pipes on your bike Chrislib. What muffler have you got on that bike?
