Author Topic: Rebuild Kits  (Read 2309 times)
schmidbc
Rebuild Kits
« on: April 14, 2005, 02:50:18 PM »
I need some help guys.  I've got a '76 CB750f-1 and I'm having major problems finding rebuild kits for my rear master cylinder, front/rear calipers, and petcock.  Everything I find seems to be for the f-2.
I would prefer a US parts source but anything would be helpful at this point.   Thanks!
eldar
Re: Rebuild Kits
« Reply #1 on: April 14, 2005, 02:58:46 PM »
Well I run into this problem as well. I have 78k model. Try going to   www.crc2onlinecatalog.com/Index_Main_Frame.htm. I see a rebuild for the master for the front and if I remember correctly, you may want to double check, the front and back were identical for the caliper and may even be able to use the same parts the front master uses. I cant remember though if the F1 had a rear disk.
Offline mcpuffett
Re: Rebuild Kits
« Reply #2 on: April 14, 2005, 03:09:50 PM »
hi ,yep f1 has rear disc   mick.
eldar
Re: Rebuild Kits
« Reply #3 on: April 14, 2005, 03:23:42 PM »
I thought so, am I also correct that the master has the same construction just different actuation?
