Why are the press in giving you issues? Just pull them out. Yank the carbs off and flip them over, pull the bowls off, grab the jets with pliers and twist while yanking. Off they come. Then Use the #1 string on a guitar(the high E) and clean them out carefully. OR use a couple strands of copper wire. After cleaning them with wire, spray them with carb cleaner and spray all the fuel paths with cleaner. Re-assemble and bench sync the slides to about 1/8th inch.
Set your idle mix screws to about 1 3/4 turns out. From there, tune the idle mix. once done, then sync the carbs.
The level does not matter much, they just need to be pretty close to each other.
I yanked the pilots out of the CB650 carbs I had, but it tends to score up the outer body of the pilots pretty good. Will this cause any real issues? One pilot bent a bit, but the other three came out pretty clean, just light scoring from the pliers.
I read one of your other posts about the E string and copper wire, pretty informative, thanks Eldar!
1 3/4 it shall be, and I'll sync them to eachother, adn not worry too much about the levels. -That's really the main thing I needed to know.
I know it's a bit of a crapshoot figuring out jetting, but with pods and an open header, no engine mods, stock ignition, what do you suspect I should be running for jetting?
The drilled out 120s seem to work pretty good, but without fixing my pilot jet issue, I can't really figure out if my jetting is spot on... What'd be your guess for jetting?
I've got an old jet kit from a '98 Katana 600 I had years ago, and the jets are the same thread as the Honda jets, so I've got 114, 110, &116 on hand as well.
I seem to recall hearing about running pods that the center pods are restricted more for airflow than the outer pods, and as such, many run different jets for the center carbs compared to the outer? -Anyone heard this? Applicable to the CB750?
