Author Topic: SL350 Engine vs CB/CL350 Engine Questions  (Read 20686 times)
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« on: November 20, 2008, 11:19:38 AM »
 My situation concerns the fact that I have a SL350K2 rolling frame and a CL350 engine. Now, I am aware that the SL head has different porting along with a different cam for more torque (also has non-CV carbs). My questions are : #1 Would getting an SL cam and putting it in the CL head be worth the effort? #2 Or would the SL head be needed to make it worth the effort? I can get the cam for $20. This bike will be built for messing around in the woods (up and down hills too) and never see any "road time", while I have it.
Opinions? Comments?
Member # 1969
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: SL350 Engine vs CB/CL350 Engine Questions
« Reply #1 on: November 20, 2008, 11:33:02 AM »
Doesn't the SL also have a lower ratio top gear?
I doubt there is really a noticable difference in most applications between the SL and CB/CL power delivery. I probably wouldn't bother.
No.
« Reply #2 on: November 20, 2008, 01:49:26 PM »
I am not so sure heads are different or even the cams.. sure you can mix and match it all.
What I do know, first SL had CV,s I think, then changed..
 differnt cases on SL,s, maybe not 1st year..
some 350 twin rockers are different,  early ones allow more lift I think..
 I have CB350 partsbook, maybe SL too, if so I can provide proof with numbers..
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #3 on: November 20, 2008, 02:00:54 PM »
Only thing I heard was different was the top gear.
And the frame is different..
But I never heard of head and cam being different.
I've been wrong about plenty of stuff though.
No.
Offline bill440cars
« Reply #4 on: November 20, 2008, 02:12:59 PM »
       Wasn't sure about the gear ratio between the 2. The only difference between the CB350 and the SL350K1 was 3rd gear (1.269 vs 1.280) which jumped the Final Gear Reduction from 2.250 (with a 16T countershaft Sprocket & 36T Drive Sprocket vs 2.500 (no input about SL  sprockets). Then the SL350K2 is TOTALLY different:
             CB350          SL350K2              SL350K2
    1st     2.353           2.353                 2.866
    2nd    1.636           1.636                 1.800
    3rd     1.269           1.280                 1.333
    4th     1.036           1.036                 1.035
    5th     0.900           0.900                 0.870
   Final    2.250           2.500                 2.625
    I used to have the differences around here somewhere and can't seem to find them right now. I have to check out the fit of the Cl engine into the SL350K2 frame also. You see, the SL350K0 was the only SL350 with the electric starter and the frame was completely changed for the K1. I Have /u] noticed an upper half of an SL350 case along with the alternator housing on ebay also and the price doesn't seem too bad. You see, I'm probably going to have to get into this engine anyway. That SL head might even have smaller valves, I don't remember right off. Appreciate your input Mark. ;)
Member # 1969
Offline bill440cars
« Reply #5 on: November 20, 2008, 03:06:38 PM »
      Yeah, the frame was changed for the K1 model and a 21" front & 18" rear wheels (K0 & K1 had a 19" front & 18" rear) along with aluminum fenders were added on the K2 model. I had read somewhere about the differences and can't seem to find it now! ::) When and If I find it, I'll post it. There were a number of changes in the short time the SL350 was produced, just to try to keep it on the market and be competitive, but the XL250 and then the XL350 were replacements.
   By the way, I just went to Crotchrocket.com and found the P/N for the SL350K2 Cam, which I then cross referenced to see where all it was used and the only 350s that used that particular cam was the SL350K1 & K2.
All Records   Click on the  to view this parts assembly.
Click on the to view this parts supersession history.
Sku      Model   Description   Req   Price           View
14101-312-030    View Sku Supersession
Loading...
SL350K1 A MOTORCYCLE, JPN, VIN# SL350-2000001
Assembly: CAMSHAFT + VALVE
   CAMSHAFT (Honda Code 0229971) (SKU: 14101-312-030) (Superseed: 14101-312-040)    1    $249.57    Add to Cart        [Click to view details]
Loading...
SL350K2 A MOTORCYCLE, JPN, VIN# SL350-3000001
   CAMSHAFT (Honda Code 0229971) Use up to Engine SN 3021782 (SKU: 14101-312-030) (Superseed: 14101-312-040)    1    $249.57    Add to Cart
   I then went back and checked the head P/N and found out the same thing. I haven't gone any further. I'm just trying to find out what differences there are and what parts are the same.
12200-312-000    View Sku Supersession
Loading...
Assembly: CYLINDER HEAD + SPAR...
   CYLINDER HEAD (Honda Code 0230482) (SKU: 12200-312-000) (Superseed: 12200-312-010)    1    $466.63    Add to Cart        [Click to view details]
Loading...
   CYLINDER HEAD (Honda Code 0230482) Use up to Engine SN 3024697 (SKU: 12200-312-000) (Superseed: 12200-312-010)    1    $466.63    Add to Cart        [Click to view details]
     I hope you all understand that I'm looking to learn all I can about the differences between them and use that info to my advantage and that's all.  ;)
                   Thank you Mark & Frank for your input, Bill
Member # 1969
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #6 on: November 20, 2008, 03:09:19 PM »
The downtubes were different on the SL, that was what wa smost noticably different to me.
Supposedly a litte stiffer, so some of the cb350 racers like to get ahold of the SL frame, and they like the gearbox from the SL more, too.
No.
« Reply #7 on: November 20, 2008, 03:24:26 PM »
Different downtubes?? whole new frame I think, the CB is a single downtube splitting near the bottom and SL is twin downtube.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #8 on: November 20, 2008, 03:30:18 PM »
I wasn't saying they werent different frames, I was saying that was the difference I noticed.
No.
Offline bill440cars
« Reply #9 on: November 20, 2008, 04:45:33 PM »
       Okay, I just did some more P/N checks and comparisons and I'm getting the idea that the SL350K0 engine was just a basic 350 twin. The head P/N for the SL350K0, also relates to the CB & CL350 heads.
12200-287-080    View Sku Supersession
Loading...
SL350 A MOTORCYCLE, JPN, VIN# SL350-1000001
Assembly: CAM CASE + CYLINDER ...
   CYLINDER HEAD (Honda Code 0112698) (SKU: 12200-287-080) (Superseed: 12200-287-110)    1    $401.81    Add to Cart        [Click to view details]
Loading...
CB350 A MOTORCYCLE, JPN, VIN# CB350-1000001
   CYLINDER HEAD (Honda Code 0112698) Use up to Engine SN 1020152 (SKU: 12200-287-080) (Superseed: 12200-287-110)    1    $401.81    Add to Cart        [Click to view details]
Loading...
   CYLINDER HEAD (Honda Code 0112698) Use up to Engine SN 1087815 (SKU: 12200-287-080) (Superseed: 12200-287-110)    1    $401.81    Add to Cart        [Click to view details]
Loading...
   CYLINDER HEAD (Honda Code 0112698) Use from Engine SN 1017816 to 1107339 (SKU: 12200-287-080) (Superseed: 12200-287-110)    1    $401.81    Add to Cart        [Click to view details]
Loading...
   CYLINDER HEAD (Honda Code 0112698) Use from Engine SN 1017816 to 1131066 (SKU: 12200-287-080) (Superseed: 12200-287-110)    1    $401.81    Add to Cart        [Click to view details]
Loading...
CL350 A MOTORCYCLE, JPN, VIN# CL350-1000001
Loading...
Loading...
Loading...
      Be interesting to know how much Honda spent trying to keep the SL350 in production.  Frame, Carbs, 21" front wheel, gastank, fenders switched to aluminum, head, the top of the triple tree, is the same as the early XL250 & XL350, best I can find out (by P/Ns), yhe K0's rear rim was only made for the K0! Also, I think I remember that the top part of the triple tree of the K0, was made only for the K0 (by P/N).
          You know, I have all of the respect for the first model of nearly anything but, if I had the choice of an SL350K0 and an SL350K1 or K2, I wouldn't even have to think about it, the K2 would be sitting in my driveway ASAP! I'm not sure about the K2, but I read that there was the Sl350K1 weighed 60lbs less that the K0! (frame, no electric starter and smaller battery for sure. Not sure what (if anything else) else.
                         More coming as I get it. ;)
Member # 1969
Offline darkbane
    • Half Fast Chicago
« Reply #10 on: November 20, 2008, 07:13:50 PM »
I just purchased a '71SL350K1 a few months back to make a small bobber project.  I also have a '72 CL350K2.
The SL350 is MUCH Lighter than the CL.  Granted mine is pretty stripped down...can be seen here:
http://www.halffastchicago.com/forum/index.php?topic=173.0
Not having the ugly front starter, aluminum wheels, smaller headlight, super light weight Exhaust (CL pipes are heavy), all seem to make a weight difference.  Unfortunately I don't have my project running to be able to tell you the difference in power/torque.
'71 SL350 Dirt Bike Bobber Project
'83 GS650G
'72 CL 350k4
Offline bill440cars
« Reply #11 on: November 20, 2008, 08:57:22 PM »
darkbane,
               I just got through checking out what you have gone through with your SL and you are making Quite a statement with that one. 8) Thanks for posting that link so we could check it out! 8)
       I figure on leaving off anything that's not needed, but, mine will not be on the street, so I'll be looking into a low cost way to eliminate the battery, all lights and might see about making a wiring harness that will only include the necessary wires. Mine will be running trails, going through the woods and such as that. So, with that being said, I will definitely be keeping the rear suspension.
                            Take care, Bill ;)
Member # 1969
« Reply #12 on: November 20, 2008, 09:03:39 PM »
Bill, do you have pics of a yellow rig??
I got the part #s for K5 CB/CL 350 and Ki SL 350 , the heads and the cams are different.. I am starting to think maybe SMALLER ports on ths SL...?
Offline bill440cars
« Reply #13 on: November 21, 2008, 03:39:45 PM »
   Frank, I'll have a PM to you later this evening. I do have some pictures. ;)
    Now, I have another question about the SL350. The Sl350K2 weighs about 306lbs. If I can successfully eliminate the battery, lights, lights and mufflers (and anything else that I or you all can think of), leaving it with either the aluminum fenders or plastic ones, it makes me wonder just how much weight I can shave off of it? Honda took about 60lbs off of the SL350 when they removed the electric starter, Changed the frame, reduced the size of the battery and I don't know what all. I'll probably use the aluminum stock fenders, since I have them. Thinking about making a wiring harness that would include only the necessary wires and putting the original harness up (that would save some weight. If I put an aluminum, plastic or fiberglass tank on it. that would help too. Thinking about pods instead of air cleaners and a smaller (lighter) seat also.
         Here's a shot of an SL350 K2
        And here is one with plastic fenders
Member # 1969
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #14 on: November 21, 2008, 03:49:17 PM »
Pretty sure the SL came with aluminum rims, too.
Theres some weight loss, too.
No.
Offline bill440cars
« Reply #15 on: November 22, 2008, 09:25:15 PM »
      I AM getting kinda interested in getting to the point to where I can see just how much more weight I can shave off of this bike. 8)
Member # 1969
Offline bill440cars
« Reply #16 on: November 23, 2008, 01:21:36 PM »
       Not sure about that Mark, mine doesn't, but I don't know how much of mine is stock. Since my last post here, I've learned that I can't just swap out the upper case half, to get rid of the electric starter mount. I'm going to have to swap out both case halves and the left side cover (that mounts the alternator stator coils) also or carefully trim off the part of the upper case half that the starter mounts on and reshape it, where I would have cut it off. Oh well, I've got time. ;)
Member # 1969
Offline scunny
  • don't call me expert
« Reply #17 on: November 23, 2008, 01:31:49 PM »
Bill, does it require the battery to run or does it just need that for the starter and lighting ?
my 79 XL250s had a battery but I just junked that since mine is purely off road.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline bill440cars
« Reply #18 on: November 23, 2008, 03:12:12 PM »
        I believe that it is setup to include the battery, like the CB & the CL. Best I know of, it has basically the same electrical system. That capacitor setup, I was talking about, would take a charge as the engine was running and hold it, making it capable of using some lights while the engine was running. Not sure what kind of electrical system the XL has, since I haven't had any experience with those. I HAVE had some time with 2 stroke enduro type bikes of the early 70's and I could just unplug the ignition switch, if I couldn't find the key (it had a magneto though). The  SL350 has an alternator and that's why I don't think I can make it work without some sort of "Battery Eliminator". Appreciate the input though. I'm ALWAYS open to suggestion. ;) How's that XL doing BTW?
Member # 1969
Offline scunny
« Reply #19 on: November 23, 2008, 03:15:49 PM »
haven't ridden in 4 months due to a bung shoulder so my brother has borrowed the XL. he says it's running great
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline bill440cars
« Reply #20 on: November 23, 2008, 03:24:23 PM »
        That's good that the XL is running great, not so good that you've got that shoulder problem. How much longer you going to be down with that? Hope things are healing up quite well. ;)
Member # 1969
Offline scunny
« Reply #21 on: November 23, 2008, 03:30:24 PM »
off work for probably another 3-4 months.
on the bright side I should be able to finish the 650 soon
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline TomC
« Reply #22 on: November 23, 2008, 05:47:59 PM »
Hi Bill
     Do the CB, CL, & SL 350s have a permanent magnet rotor in the alternator? If so they can be made to run with out a battery.
          TomC in Ohio
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
Offline bill440cars
« Reply #23 on: November 23, 2008, 08:28:16 PM »
Hi Bill
          TomC in Ohio
       Tom, I owe you an apology. When I saw your post here just now, I thought I remembered seeing that question before, so I checked and found that you'd posted over on the Battery Eliminator and I never responded to it. :( Completely slipped my mind. Sorry bout that. Now, to answer this question. Yes, the SL350 (I assume the CB & CL are the same also) has a permanent magnet type rotor. S, I am all ears, as to what I need to do to make this engine run without a battery. 8)
Member # 1969
Offline TomC
« Reply #24 on: November 24, 2008, 07:35:29 AM »
Hi Bill
     With a permanent magnet rotor alternator electrical power is being generated any time the crankshaft is being turned. If the crankshaft is spinning fast enough the alternator will produce enough power to run the ignition system.
     The first question is can you kick it over fast enough to start. My guess is the answer is yes.
     My guess is that the 350s use a bigger & better version of the charging system on my Super 90. Which has six generating coils. One pair of coils is connected when the engine is running and the other two pairs of coils are switched in when the lights are turned on. There is a rectifier but no voltage regulator. Voltage regulation is by matching the load with the output of the alternator and using the battery to take or give back the difference.
     If the 350 is of this general type you can test to see if you can start with out a battery by. Get a capacitor. I have a 10,000uF that I payed $2.50 for should be more that enough. With the key of the 350 turned off, and it stays OFF for all of this, connect the capacitor in place of the battery. The capacitor should be polarity sensitive. The one I have has a black dot on the negative terminal. At this point put a voltmeter across the capacitor and give the kick starter a few kicks and see how much voltage is produced. I would expect to see at least 15V. If there is good voltage then connect the positive terminal of the capacitor to the wire going to the coils, black with a white stripe maybe?, and try to start the 350. If the 350 starts great. If not adding the lighting coils will help.
     If the 350 started the next problem is that the alternator may be making more power that the ignition system needs. An automotive ballast resistor in series with each coil may be enough. Test for this problem by checking the voltage across the coils.
     Do you have a link for a 350 wiring diagram, just the diagram please, that I could down load. It would help me to keep from sending you down the wrong road.
          TomC in Ohio
TomC in Ohio
