Author Topic: Gentleman's Express Gen II  (Read 2323 times)
Offline Ricisan
« on: November 21, 2008, 08:37:46 AM »
I finally finished my teaching credential and promised the other half that my 78 550K would be next on my list. I've been hauling it around for almost 20 yrs, it's time to finish it.
I'm surprised that I haven't seen anyone else do what I am doing. I found some CB 1000/900 forks w/dual piston callipers. They are 35mm and slide right in. The forks are longer, but so are my WP shocks.
Are the newer forks any better than the orignal 550/750 forks? Can they be modded?
The callipers were now wider than the dual disks bolted to a stk 550 hub. I spaced the callipers in w/washers for now to mock it up. The disks had to be thinned so as to fit the new callipers. The newer disks would not bolt up to old hub, 5 hole vs 6 hole. That's all I've done so far.
Next on my list is getting the carbs cleaned, then start checking the elect before messing w/Dyna ign.
I have everything I need, I just have to get things working together. This forum has been both helpful and inspiring, especially the "Inspiration Gallery".
I'm not skilled enough to post pics yet. I will be making progress reports as I complete things.
Any suggestions for a different/better/cheaper ign system? The locking barrel is old and replacements are expensive from what I have seen. Thanks for all the ideas.
Ricisan
Offline DollarBill
Re: Gentleman's Express Gen II
« Reply #1 on: November 22, 2008, 05:31:24 AM »
Gentleman's Express ala BMW?  I wasn't sure what it was so I had to google it and a few things came up but I figured the beemer was the likely culprit.  Let's see some pics!
1975 CB750F Project Yellow Jacket - CBR600rr Swinger GSXR 600 Forks
1955 BMW R25/3, 1966 Honda CA160, 1975 CB400f, 1975 CB550, 1976 CB550
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #2 on: November 22, 2008, 06:38:43 AM »
Ricisan
Heres 2 DIY ignition system links
http://geocities.com/loudgpz/index.html#home
Click on the Electronic ignition ststem PDF
http://www.3cyl.com/~diamondj/
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #3 on: November 22, 2008, 08:17:06 AM »
The Gentleman's Express refers to an article from Cycle magazine way back in the ‘70’s. They did a review of a refined CB550 owned by one of the magazine’s journalists. That bike had CB750 pistons fitted and hotter cam, alloy rims with better rubber, suspension mods etc etc. Real nice package.
The article is available on this site somewhere. Keep looking.
FJ
fuzzybutt
« Reply #4 on: November 22, 2008, 08:21:55 AM »
Ricisan
or throw hondaman some business.........  http://forums.sohc4.net/index.php?topic=40485.0
« Reply #5 on: November 22, 2008, 10:10:09 AM »
gentleman's express article
here it is, for your reading enjoyment
Offline Ricisan
« Reply #6 on: November 22, 2008, 07:20:09 PM »
I have a Dyna system and coils in the box. I ment the ign switch/lock. I want to get it to run before I start changing parts. I'm a little concerned but it's time to get this done. I have alloy rims and good rubber, Marz shocks and a few other goodies. Once I get started I will post pics.
Ricisan
