Author Topic: Megacycle hardwelded cams  (Read 4092 times)
sohc4
« on: November 21, 2008, 02:21:18 PM »
Anyone have experience with a Megacycle hardwelded cam? Is it ok to run it with stock rocker arms, or will I need hardwelded or otherwise treated rocker arms as well?
Thanks,
Axl
Re: Megacycle hardwelded cams
« Reply #1 on: November 21, 2008, 03:12:08 PM »
 I have used both Megacycle and Web hardwelded cams. The only problem I've encountered is a reduced base circle which can cause a problem with shim/bucket arrangements (if you are near the end of the thick shim range to begin with). I would use used rocker arms but they would have to be in excellent condition. New rockers or, better yet, hardwelded would be the most desireable set up. The hardwelded Megacycle rockers are real nice but very expensive.
Offline Maxacceleration
« Reply #2 on: November 21, 2008, 04:29:38 PM »
So would a re-grind cam be better with stock rockers then?
Olden is Golden
CR550F RD400 KZ550 KH500
« Reply #3 on: November 21, 2008, 07:21:55 PM »
You can't get a large cam with just a regrind
« Reply #4 on: November 21, 2008, 08:42:20 PM »
Webcam sells two reground higher performance cams...???
http://www.webcamshafts.com/ (won't open directly to page)
Olden is Golden
sohc4
« Reply #5 on: November 21, 2008, 11:52:54 PM »
Thanks, Mike, that's what I wanted to hear   :)
Axl
« Reply #6 on: November 22, 2008, 06:31:19 AM »
You are absolutly correct...... I just consider those cams mild. ;) If you want something in a .375 or .400 lift  you need to hardweld. The Megacycle 125-65 and 125-75 are my all time favorites (especially the 75).
sohc4
« Reply #7 on: November 22, 2008, 07:32:57 AM »
May I add the 125-25 to the favorite list  ;)
Axl
« Reply #8 on: November 22, 2008, 07:43:50 AM »
Axl
Yes you may Axl. ;)
sohc4
« Reply #9 on: November 23, 2008, 02:05:30 AM »
Offline HawaiiMike
    • Hawaii realtor
« Reply #10 on: October 02, 2009, 11:10:21 AM »
Webcam's price is $164, seems like a better deal than Megacycle.
Here are the specs for Webcam's CB550 cam: http://www.webcamshafts.com/pages/motorcycle/honda/install_data/tc_1724_131.html
Offline Kevin
« Reply #11 on: October 02, 2009, 11:49:25 AM »
$164 is for a re-grind, not the hardwelded cam, the hardwelded is $322.00.
I am a Webcam dealer and can get a better price for you if that's the route you want to go.
Kevin
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
« Reply #12 on: October 02, 2009, 02:01:18 PM »
What would be a good cam for an 836 with a mild ported head and 4 into 1? Cafe type riding. No heavy loads.
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #13 on: October 02, 2009, 02:09:09 PM »
what carbs?
Mark Twain - Notebook, 1894
