Author Topic: Comstar CX500 Rear Wheel 16"  (Read 1329 times)
Offline A Grove
  • Some people call me a
« on: November 21, 2008, 04:19:31 PM »
Hey all, found this while surfing for some parts for a new project...
http://cgi.ebay.com/ebaymotors/_Motorcycle-Parts-Accessories__Honda-CX500-Rear-Wheel-Comstar-16-Hub-Axle_W0QQitemZ260300714015QQadiZ2863QQadnZMotorcycleQ20PartsQ20Q26Q20AccessoriesQQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item260300714015&_trksid=p4506.c0.m245&_trkparms=72%3A543|65%3A12|39%3A1|240%3A1318
Does anyone have any clue if it will directly bolt-on to a '77 cb550 swing arm?  If not, what modification is needed?  I'm not worried about the brake, etc - I need to make all new linkages for the new pegs anyhow.
Thanks
fuzzybutt
Re: Comstar CX500 Rear Wheel 16"
« Reply #1 on: November 21, 2008, 04:23:03 PM »
cx500 is a shaft drive, wont work on out cb's
Offline A Grove
« Reply #2 on: November 21, 2008, 04:26:14 PM »
Damn... Really wanted to pick that up if it was going to work!!
Offline cb650
« Reply #3 on: November 22, 2008, 06:09:50 AM »
Thats the same wheel the 650 customs use but in chain drive.  Someone here has put them on a 550.
PM me if you want one or a set.
Offline A Grove
« Reply #4 on: November 22, 2008, 10:34:27 AM »
PM'd you!
Online Alan F.
« Reply #5 on: November 22, 2008, 02:20:04 PM »
In the thread entitled, Nighthawk wheels on 75 CB750F   Member 754 mentioned the fact that most shaft drive wheels have a drive collar that you can unbolt from the wheel, and replace with a custom fabricated sprocket carrier, which can be one solid piece, without a cush drive, with no worry for cracking the wheel.   I'd read somewhere on a chopper forum that people were using shafty wheels with a chain, but never knew how until then.
