Author Topic: What a stud!!  (Read 3781 times)
What a stud!!
« on: November 22, 2008, 09:05:18 am »
I haven't seen many of these 500/550 studs lately but got lucky and ended up in the right place at the right time.
HD studs for these engines are maybe not as critical as with a 750, but it can't hurt.
Re: What a stud!!
« Reply #1 on: November 22, 2008, 10:39:19 am »
Nice find! How about scanning that info sheet and we can get someone to load it into the site.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
Re: What a stud!!
« Reply #2 on: November 22, 2008, 10:56:04 am »
nice find, brent. i keep meaning to compare the length of the 550 studs to that of the 650 bolts... theoretically they should work. they are the same diameter as the HD cb750 studs, and torque to 22 ft#.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: What a stud!!
« Reply #3 on: November 22, 2008, 11:19:58 am »
Great find.
If you come across any more, let me in on it.
Cheers
Jimmy
Re: What a stud!!
« Reply #4 on: November 22, 2008, 12:50:00 pm »
These are brought to you by the good folks at Kibblewhite. Something is amiss with my scanner (or the operator) but it's just installation info. Recommended torque is 20-22 ft. pds also.
Offline heffay
Re: What a stud!!
« Reply #5 on: November 22, 2008, 08:11:13 pm »
ya, so... type it in!   ;D
we like installation info.   :)
Re: What a stud!!
« Reply #6 on: November 22, 2008, 09:37:36 pm »
I thought Kibblewhite discontinued those studs a long, long time ago. ???
Re: What a stud!!
« Reply #7 on: November 22, 2008, 10:41:04 pm »
NOS find...
speaking of which.. I found and NOS sohc 650 head today, if anyone need one..
Re: What a stud!!
« Reply #8 on: November 22, 2008, 10:47:47 pm »
I'm quite sure they did Mike, the info sheet is like rare parchment! It's been a dogs age since I've seen these things.
Re: What a stud!!
« Reply #9 on: November 22, 2008, 10:55:00 pm »
I'm not going to bore you with the details Hef, it's just a double nut kind-a-deal.....dig?
Offline heffay
Re: What a stud!!
« Reply #10 on: November 23, 2008, 06:57:15 am »
double nuts... gotcha.    ;)
Offline paulages
  • 1976 cb735
Re: What a stud!!
« Reply #11 on: November 24, 2008, 12:31:21 am »
i feel like i should keep this one secret, but i just checked and i'm 99% positive the 650 bolts will work instead of the 550 studs. i'd want to actually bolt one up to say for sure, but they are pretty much the same length taking into account that the head of the bolt compensates for a little bit of thread portion at the top of the 550 stud. 650 bolts: as stout as the APE HD CB750 studs, and torque the same. downside: studs make installing the jugs easier, as they hold the cylinders upright.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline BlindJoe
Re: What a stud!!
« Reply #12 on: November 24, 2008, 03:51:28 pm »
What is the theory behind using bolts to hold these things together as opposed to studs and vice versa?
Re: What a stud!!
« Reply #13 on: November 24, 2008, 04:47:56 pm »
Brent, I thought for a minute you were talking about me. ;D ;D ;D ;D ;D ;D
Sam. ;)
Re: What a stud!!
« Reply #14 on: November 24, 2008, 07:56:31 pm »
Sam. ;)
What makes you think I wasn't?  ::)
Offline BlindJoe
Re: What a stud!!
« Reply #15 on: November 24, 2008, 08:26:56 pm »
nobody?
Offline paulages
  • 1976 cb735
Re: What a stud!!
« Reply #16 on: November 24, 2008, 10:42:09 pm »
can't answer that from an engineering perspective, but from a practical perspective i can tell you that both have clear advantages and faults. studs: can be difficult to remove if necessary, but provide good alignment of cylinders upon assembly. also, you have to torque the bolts into the case as well as the nuts to the studs. seems like more room for error and stretch to me, but i'm no expert. bolts: easier to replace, and less thread to bugger up.
there must be a reason they used studs to begin with though? the threads are actually larger than the diameter of the stud, unlike the HD studs and 650 bolts.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Soos
Re: What a stud!!
« Reply #17 on: November 25, 2008, 12:17:34 am »
NOS find...
GAAAA......
Um.... i'll take that off your hands....
Not useful afterall... you pay shipping?
 :o :o ;D ;D ;D
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline heffay
Re: What a stud!!
« Reply #18 on: November 25, 2008, 12:41:11 pm »
bolt = more working room inside the frame for head removal etc.
stud = ease of installation of cyls and head for reasons already stated
bolt = little nasties get in the holes and gum up the thread
stud = no holes for little nasties (unless replacing studs)
i've worked on both and i believe the studs to be FAR superior.  not really in strength, perse, just all around ease of doing the job.
« Last Edit: November 25, 2008, 12:55:39 pm by heffay »
Offline ct_racer
Re: What a stud!!
« Reply #19 on: November 25, 2008, 12:42:03 pm »
Wow, nice find I wound up having to have a metal shop custom me up some.
Re: What a stud!!
« Reply #20 on: November 25, 2008, 12:51:23 pm »
I agree the biggest drawback with a bolt is the potential to damage the upper case thread.
For that reason alone the stud gets my nod.  ;) (How's that Sam?)
Offline BlindJoe
Re: What a stud!!
« Reply #21 on: November 25, 2008, 02:03:19 pm »
Cool, thanks for the replies, I was just curious, seemed odd they would just use bolts for the 650s and not the others.
Offline heffay
Re: What a stud!!
« Reply #22 on: November 25, 2008, 02:06:38 pm »
those of us in the know (the ones that don't own a cb650)... consider the 650 the bastard child of Honda and the CB family.   ;) ;D
 :P :-*
Offline ghost
  • what do you mean i can't do that? I just did it didn't i
  • it's all about the last inch baby(even when it's metric)
Re: What a stud!!
« Reply #23 on: November 25, 2008, 02:32:18 pm »
 :P :-*
that's cold hef, might be true, but that's still cold. i love my 650 better head design, no points to mess with, guess papa honda saved the best (sohc4) for last
1980 cb650c first bike i owned now the wife's ride.           1982 xv920j virago, bike i learned to ride on rescued it from a 13 year coma (sitting in the shed) now she runs beautifully and rides like a dream.
Offline heffay
Re: What a stud!!
« Reply #24 on: November 25, 2008, 02:36:57 pm »
oh man... i hate adjusting the valves on the 650.
350 is much nicer.  MHO
