Author Topic: What a stud!!  (Read 3777 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
Re: What a stud!!
« Reply #25 on: November 25, 2008, 07:13:26 pm »
Cool, thanks for the replies, I was just curious, seemed odd they would just use bolts for the 650s and not the others.
i will say this: much of the 650 design was an obvious improvement from the earlier SOHC4s. the styling may have slipped a little (IMO, which is correct of course  ;))... but from port, clutch, and combustion chamber improvements, to a removable lower frame tube for engine R&R... there are several obvious moves forward from 1969. bear in mind the 650 had only 5 BHP less than the '69 cb750. i'd wager that the bolts rather than studs were not an accident. at the very least, they were the only SOHC studs/bolts to have a stock torque value over 20 ft/lbs.
another argument for bolts is that either will reach a permanent fatigue after several torquings. bolts would be easier to replace.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Re: What a stud!!
« Reply #26 on: November 25, 2008, 07:23:02 pm »
The ports from the 650 to the 550 are light years away from each other.
