SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Rear disk brake mount point on swingarm, on top or bottom?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Rear disk brake mount point on swingarm, on top or bottom? (Read 1302 times)
Soos
Just a butcher with a carbide hatchet, definitely not a
Master
on:
November 25, 2008, 07:05:05 am »
I'm putting a 16" rear rim with a disk brake on it onto my '82 cb650.
The cb650's swingarm mount point for the bar that goes to the stock drum brake is on the bottom.
The donor bikes stock mount point for the bar that goes to the rear disk hangar is on the top.
Other than the added difficulty bleeding the brakes, is there a difference where the mount point on the swingarm is located for a disk brake setup?
BTW, donor bike is a '85ninja600
l8r
Logged
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
bryanj
Really Old Timer ...
CB500 Number 1000036
Re: Rear disk brake mount point on swingarm, on top or bottom?
Reply #1 on:
November 25, 2008, 10:13:38 am »
If you put the caliper under instead of on top not only will it be a swine to bleed but it will also fill up with crap quicker and sieze sooner
Logged
dusterdude
Reply #2 on:
November 25, 2008, 12:52:31 pm »
to bleed it,temporarily put caliper on top,then mount back on the bottom.to prevent gunk,clean out the caliper,brake line and master cylinder and run dot 5 fluid.been running like that on my panhead for 15 years,no issues.
Logged
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Soos
Master
Reply #3 on:
November 26, 2008, 08:19:59 am »
'49?
Nice...
Why DOT5?
Personal preference, or is there a specific reason?
l8r
Logged
-=≡ Soos ≡=-
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
