Author Topic: clutch rattle  (Read 914 times)
Offline torrinh
  • If you don't ride in the rain, you don't ride.
clutch rattle
« on: November 25, 2008, 11:23:38 AM »
When I start my 1978 CB750K when it's cold the clutch sounds like a tin can full of pebbles. Starts , runs, fine. After she warms up a bit she quiets down a little. Is this normal?
Thanks
1983 Kawasaki GPZ 750
1978 Honda CB750K w/ 1976 CB750F1 motor
1979 Suzuki GS550L
Offline XJrusso96
Re: clutch rattle
« Reply #1 on: November 25, 2008, 03:08:32 PM »
There could be a few different causes for clutch chatter.  What viscosity oil are you running? Sometimes in the cold if the oil is to thick the plates can stick and chatter and what not.  Or just check the condition of your clutch for burnt, glazed, or warped friction plates.
Offline eurban
Re: clutch rattle
« Reply #2 on: November 25, 2008, 04:06:37 PM »
Some amount of clutch rattle is unavoidable on the SOHC4.  Assuming your 78's clutch is stock, it already has the updated clutch that is a bit less prone to rattle.  A smooth running engine will rattle clutch plates less; in particular, synchronizing the carbs will help.  Still going to sound like a bucket of marbles tho, particularly when the engine is cold and not running smoothly . . . .
