Author Topic: homemade bike lift  (Read 10402 times)
homemade bike lift
« on: November 29, 2008, 01:06:28 pm »
well you kinda gotta have access to some pipe steel, and of coarse a welder.  but this thing works like a charm.  no new idea's here.  just my take on something that already existed, i just kinda simplified it . i'd be happy to give the measurements on this thing  ...   but if your gonna make it, you mostly already know how to use a tape measure
 i think it's pretty self explanatory but i will happily go into detail if someone wants
i would sell them , but it's kinda big and weighs about 15-20 lbs so the shipping would be nothing nice
Offline KB02
Re: homemade bike lift
« Reply #1 on: December 02, 2008, 04:35:57 am »
A loop or handle at the end would make lowering the bike a little easier, too.
Great concept.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline grumpy
  • ..... '73 750K3 .....
« Reply #2 on: December 02, 2008, 07:16:13 am »
What are you using for jack points on the bike?
« Reply #3 on: December 02, 2008, 08:30:50 am »
the frame rails, there are notches cut in the lift
Offline Freaky1
« Reply #4 on: January 07, 2009, 08:50:27 am »
About using one in the back, can you put it up on both at the same time? and are there issues with it pulling or sliding the front one back as you put it up?
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
« Reply #5 on: January 07, 2009, 10:29:43 am »
i dont use them both at the same time, that would be far to risky for me to attempt
as you see in the video it does pull the bike forward
Offline latheboy
« Reply #6 on: March 11, 2009, 09:21:01 pm »
This is one i found while doing some research for work....
http://www.stargis.net/webslinger/Docs/Motorcycle_Lift_assembly_Rev1K_030707.pdf
Might be good for someone
I'm a genius trapped in the body of a dickhead
Offline lordwhimsey
« Reply #7 on: March 17, 2009, 05:02:03 am »
Here's the one I use: http://www.sportster.org/tech/rickko-lift/
I don't have any welding equipment so it was perfect for me. I use it on my Sportster and my 550 and it works a treat, although that massive block of wood is a bit cumbersome.
Never kick a man when he's down, he may get back up again
flatcat
« Reply #8 on: February 21, 2010, 03:06:59 pm »
Here is one I found at at a chopper site a while back. Click on the the plans at the top of the picture.
« Last Edit: February 21, 2010, 03:11:07 pm by flatcat »
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=oqva8siameaua7e1hsph75cff1&/topic,60973.0.html
« Reply #9 on: February 22, 2010, 01:27:12 am »
i have build this ..to work on hole bike a same time,,both veels off,,,but like yours simple idea...
« Last Edit: February 22, 2010, 01:31:19 am by strynboen »
i hate all this v-w.... vords
