Bouncer:
Sorry to tag along here. But if the needles are non adjustable, how does this effect tuning for little things like pods and exhaust?
Does anyone offer a solid after market rebuild kit to replace these non-adjustable needles?
For exhaust headers that actually work, the mainjet change is sufficient tuning. For pods, IMO, the best thing to do there is to get ones that also have the velocity stack inside, as this will ease the flat middle spot problems for these pulse-type carbs. There was a thread about 2 years ago over this situation.
Others: thanks for the great info and pictures! Right now, all I see from the existing 'F' parts is an improvement for the fuel bowl levels. If the vent line(s) are routed to a moderate vacuum source, like the airbox, then this will help raise the float bowls in prolonged high-RPM situations. The 'K' likes this change.
I'm also now curious about the F3/K7-8 heads: did they share the same guide wear situation? According to the info I have for the 'F',(Honda's published shop notes, which were not always 100% accurate), the cam on the F1-F3 was the same as the cam on the K7/8. It has a bit more duration, and is a little later, than the 'K' cams. I have one K6 engine in my parts collection, and it also has the F1 "late" cam, so I suspect it sneaked into production before it was published as being there.
Next question: the early 'K' engines all sported a "ventilated cam sprocket" for lightness, which went away in the K3 to become a cheaper solid sprocket. Yosh still carried the lightened ones, and I ran mine until 2004 that way. I would like to get another one. Has anyone tried using (and measuring) the holey 'F' sprocket on the 'K' cam, and knows if it's close, or if it requires slotting, to get closer to 'K' specs? (Or, if a new one from Honda is still holey?) I'm interested in keeping with an advanced 'K' profile (3-4 degrees earlier than stock) in my next build.
