Author Topic: Gas tank welding  (Read 2237 times)
Offline Sgt Wonderful
Gas tank welding
« on: December 02, 2008, 09:16:34 AM »
I need my gas tank welded. Anyone have any ideas?
Offline goon 1492
  • Sucka Repellant
Re: Gas tank welding
« Reply #1 on: December 02, 2008, 09:33:24 AM »
Tig? Or maybe braising?
Did you do a search on this in the main forum page, I have read about others welding on them, I even saw one that had a home made guage on the side of the tank and it looked like it was braised, look closely at the tank in the pic and you can see the home made guage.
Offline johnny_from_bel
  • Member #158
« Reply #2 on: December 02, 2008, 09:41:42 AM »
Depends on what you need to be done.
Tig or brazing like said above for heavy work.
repairing pinholes con be done by soldering.
Make shure the tank is clean a free of fuel vapors.
Offline KB02
« Reply #3 on: December 02, 2008, 09:42:39 AM »
heh. Talk about your Rat Rod!!   ;D
As for the welding, what's the reason for it? Leak? Dent? Tear? Extension?
You're dealing with thin sheet metal, so whatever you becareful as it is easy to burn a hole through it.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline KB02
« Reply #4 on: December 02, 2008, 09:43:11 AM »
You beat me to it...
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline 73hutch
« Reply #5 on: December 02, 2008, 11:24:40 AM »
did you paint that header?
78-550k
72-cb100
63 c100
75 xl350
84 gl1200
Offline Tretnine
  • Prove it,
  • Figuring it out, one expletive at a time.
    • http://www.behindbarsmotorcycle.com/
« Reply #6 on: December 02, 2008, 11:37:40 AM »
if it's leaking I had really good luck with a gas tank coating product from caswell. I know there are horror stories from other tank coats, but this one worked really well for me.
2009 Kawasaki Concours, 1978 cb550k, 2006 BMW F650GS
Member of the AMA
Offline goon 1492
  • Sucka Repellant
« Reply #7 on: December 02, 2008, 01:23:46 PM »
No that's not mine but I would rock it and drive it like I stole it though  ;), pretty cool rat bike. I another member posted it here a month or so back and I had to have the pic of it, I think the owner called it dirt rocket. I like how the front is raked
Offline gerhed
« Reply #8 on: December 02, 2008, 02:49:04 PM »
Had my Indian tank welded once--after some guy backed into me.
Welder pumped an inert gas  (not sure which one)  thru the tank as he welded to keep it from exploding--he said.
          83 XL600R in CB360 Frame
« Reply #9 on: December 02, 2008, 03:21:27 PM »
I saw a mate welding a tank once. He had the filler hole over the exhaust of his running car.
It seems that it don't matter how much you wash the tank out, there will always be a small amount of gas residue in the metal of the tank.
This sorta confirms what gerhed was saying.
Sam. ;)
Offline mrbreeze
  • Not your average
« Reply #10 on: December 02, 2008, 10:55:35 PM »
I had a boss back in Wyoming that used to do it. I believe he used CO-2. That dude was a major a$$hole but he was a helluva welder.
MEMBER # 257
« Reply #11 on: December 03, 2008, 12:48:39 AM »
Here's a tank I'm "modifying" for Sean Condon, I'm only brazing in any mods like the race filler, I'm a much better mig welder than I am a stick welder, but brazing is a lot better filler than mig, and a lot easier to grind into shape, if necessary.
This tank hasn't held fuel for a long time, and when I got it I removed the cap and let it sit for a few months (winter) but having said that, I've welded tanks within minutes of removing them from bikes.
All I do is drain the fuel, then I wash the tank out with hot soapy water. I fill the tank up and swoosh it all around, dump it out, and repeat until I'm happy with it, then I get the wife to light a match and hold it over the filler while I stand behind the blast screen with the phone ready, in case I need to call the EMS, or my insurance agent............  ;D
