Author Topic: Thumping noise  (Read 1332 times)
Offline taxiscooter
Thumping noise
« on: December 02, 2008, 02:07:53 PM »
I have a 750k7 that makes a thumping noise. I noticed it at first when I made a rolling stop with the clutch in. I accelerated it back up to about 20mph and pulled the clutch back lever in and I could feel a thumping thru the foot pegs. Wasn't noticable accelerating or slowing down with the clutch engaged. Maybe the engine vibration was masking it.  It seems to cycle at an interval equal to one chain length or maybe one wheel revolution. The chain and both sprockets are well lubricated and the set have about 2000 miles on them.  Any ideas?   Thanks
Offline shoemanII
  • just another bike nut
Re: Thumping noise
« Reply #1 on: December 02, 2008, 02:22:15 PM »
first thoughts are: out of balance wheel, balanced wheel that threw a wheel weight, "tight spot" in chain, loose rear sprocket bolts, tire damage (sidewall bulge, run over a curb lately?), busted spoke(s), out of true tire or rim.  i'd check all the free stuff first, then get both wheels spin balanced if you don't find anything.
bobp
'96 ducati carb'd 900ss/cr
'72 dt2
'77cb550k frankenberry:  '77cb550k frame, '78cb550k engine, '78cb550f tank, unknown front-end
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
Re: Thumping noise
« Reply #2 on: December 02, 2008, 02:22:29 PM »
Is the chain properly adjusted?
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline taxiscooter
Re: Thumping noise
« Reply #3 on: December 02, 2008, 03:26:23 PM »
At 2000 miles ago, had new ek o-ring chain, JT front and rear sprockets. Lubed chain every 200 miles. Also at that time new rear brakes, new tire and tube, and had the wheel trued and balanced.
fuzzybutt
Re: Thumping noise
« Reply #4 on: December 02, 2008, 03:35:27 PM »
loose motor mount bolt maybe?
Re: Thumping noise
« Reply #5 on: December 02, 2008, 03:48:13 PM »
That was 2,000 miles ago, check these things again.
Sam. ;)
Offline jreich
Re: Thumping noise
« Reply #6 on: December 02, 2008, 03:56:12 PM »
I'm sure this is entirely too simplistic...but I try to make that my usual starting point; how is your oil level? When did you change it out last?
Offline Thunder
Re: Thumping noise
« Reply #7 on: December 03, 2008, 08:19:46 AM »
I had/have exactly the problem you are describing. My bike tho, HAD, been sitting for 2 years.
It seems to be the chain, but doing my rebuild slowly(insert cheapskate ;)), i decided not to spring for a chain just yet. ??
Took alot of the advice offered here when i queried the same thing.
http://forums.sohc4.net/index.php?topic=42920.0
put the bike on centre stand (i took off the engine cover hiding the front sprocket and replaced the main cover) then start the bike and watch the chain. Probably a tightspot.
i took the bike for a spin (warming the chain up) then put it back on the stand and sprayed it liberally with penetrating oil (just to loosen the links).
it's not right yet but its definetly getting better...
Good luck
