I think they started oiling them in the box around 1995 or so, at least for cars. And, they are over-oiled pretty badly on the "Filtercharger" units they sell at Checker.
All in all, it runs well once the oil pulls through, which may take a tank or two of gas. Run on lower octance gas, like regular, which will help (today's fuels burn slower, like older premium did). If you are running D8E plugs, try using D7E for a while, especially in colder weather. The D8E are too cold, even on a summer day, for these bikes. The X24ES-U from ND stays cleaner and the extended tip produces a bit more midrange torque by firing off the rich midrange a little further above the head's surface. It has an equivalent heat range to the now-gone D8ES-L plug, which was made expressly for the 750. That plug had an extended tip and a heat range of 7.5 on the same scale. It was the answer to the plug fouling problems these bikes had with the 1970s gas, until it disappeared in the 1990s.
