Author Topic: New here! any recommendations before i pull my motor for a rebuild?  (Read 2645 times)
Offline d3buttz
  • More than just an
is there anything i should do besides draining the oil warm before i dive in to this motor and tranny?  ive got a tired 1975 cb550....
« Last Edit: December 03, 2008, 05:07:50 pm by d3buttz »
http://forums.sohc4.net/index.php?topic=80508.0
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1996 Nissan pathfinder
1972 Datsun 240z
2002 Nissan sentra se-r spec-v
Offline ghost
  • what do you mean i can't do that? I just did it didn't i
  • it's all about the last inch baby(even when it's metric)
Re: New here! any recommendations before i pull my motor for a rebuild?
« Reply #1 on: December 03, 2008, 04:40:48 pm »
wash it really good, sweep the floor have plenty of your choice of beverage chilled(or hot as it may be)
1980 cb650c first bike i owned now the wife's ride.           1982 xv920j virago, bike i learned to ride on rescued it from a 13 year coma (sitting in the shed) now she runs beautifully and rides like a dream.
Offline Bouncer
  • "Bear Down"
« Reply #2 on: December 03, 2008, 04:54:20 pm »
Have extra oil-dri, and or kitty litter on hand just in case.
New to the game.
1981 CB650C (Finished) Rat Bike
1978 CB750F Project "Bear Down"
Offline Tim in Ohio
  • So I got that goin' for me, which is nice.
« Reply #3 on: December 03, 2008, 06:18:34 pm »
Take lots of digital pics from all angles so you can put things back together properly.  This will also enable you to post pics on this forum in order to ask questions of the group.  If you don't have a digital camera, beg borrow or steal one.
1973 Honda CB350  Four
Check out my CB350F resto project...  watch a complete moron build a bike in front of your very eyes!: http://forums.sohc4.net/index.php?topic=38903.0
Offline Really?
« Reply #4 on: December 03, 2008, 07:01:12 pm »
#1 - Know what you are doing.
#2 - If you do not know what you are doing, ask
#3 - If that is too hard, sell your bike
#4 - Plan and research a lot so you have a clue on what to do, what you want to do, what you can do, what you can afford, what you can't afford, what to be careful of, what to stay away from (OBB), and blah blah blah.
You get the picture.
Edit:  Oh, improve on SearchFu skills!!
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Bouncer
  • "Bear Down"
« Reply #5 on: December 03, 2008, 08:06:29 pm »
Giga's #4 point is a HUGE one. I miscalculated how much planning was involved until I tore the bike apart and realized how big of a money pit this thing is. Not in a bad way at all, but once you start rebuilding you realize all those parts you thought you may re-use you decide to replace (for a number of reasons: safety, diff direction, styling, etc) and it adds up REAL quick.
New to the game.
Offline d3buttz
  • More than just an
questions regarding my motor rebuild malarchy
« Reply #6 on: December 04, 2008, 09:15:13 am »
well, the motor was great when i got the bike, so i did rear sets, dual disc coversion-cb750 forks blah blah made the bike as well set-up as possible. i beleive im competent to take on this challenge. I want to get this motor rebuilt to 100% proper order before i add performance parts-but i want to go to a more aggressive camshaft, cr carbs and a better exhaust, igniton etc. here are my issiues
1. one of my worries is that after i replace my cam to a hot street .330 lift and a 290' duration(and of course stiffer springs)-will i have to do any thing to the pistons? i worried about my valve clearance.....my under standing is that there is 2mm clearance stock to begine with.
2. im going to have a shop do a valve job-is a 3-way worth it?
3. have plenty of time-i was thinking about a full teardown of my transmission for the purpose of inspection-but the transmission is in good working order(i will put in a new cluch and springs of course)-is it worth it to take it all the way down just to inspect and clean or do i just replace the clutch discs.Also i do leak tiny drops out of my shifter lever shaft when its at operating temperature.  Can i stop this leak w/o opening the case?.........thoughts?
3. do i replace the rockers too? if the wear isnt bad i can keep them right?
« Last Edit: December 04, 2008, 09:32:40 am by d3buttz »
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1972 Datsun 240z
Offline drackett_19
  • '75 cb550K
« Reply #7 on: December 04, 2008, 10:13:13 am »
Yeah please take lots of pictures, I've got to replace the rubber pucks under the cam towers on my 75 550 and any pics before I take the top end apart will be helpful.
cheers.
Offline ieism
« Reply #8 on: December 04, 2008, 10:33:24 am »
What's the milage? I have two 550's, both well over 50.000 miles and have no need to dive into the transmission. The gearbox still feels very good, even compared to a new bike. I did rebuild the topend.
What are you're reasons for rebuilding the engine? Cosmetic, just checking, performance?
---cb550---
Offline ieism
« Reply #9 on: December 04, 2008, 10:36:55 am »
Oh, and the shiftlever dripping oil is a common problem on 550's. It's just an O-ring that needs replacing if I remember correctly.
Do a search, and you"ll find the solution to that problem easily.
---cb550---
Offline d3buttz
  • More than just an
« Reply #10 on: December 04, 2008, 11:14:27 am »
i only have 22,000 on the motor,   the power loss im sure is the valve adjustment thats out of tune(tick tick tick tick!) in the past 200 miles and the carbs have the velocity stacks- i adjusted the fuel mix as high as i could go- i diddint want to spend 200$ on a full carb rebuild if i can get the keihin cr carbs for 700$(ouch) and get a huge difference.  thanks for the advice on the tranny- ill leave it alone-  Its bananas how cold it is out here and it'll last another 5 months ive got alot of time and drive to build the motor as fast and reliable as possible. thanks guys!
does any one have advice on the hot cam and the clearance issiue im afaraid of?
 also the cam rockers?
i want the motor to do the rest of the bike justice. vroom!
« Last Edit: December 04, 2008, 11:20:03 am by d3buttz »
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1972 Datsun 240z
montana550
« Reply #11 on: December 04, 2008, 11:31:31 am »
To add to Giga's list:
5. Print out the 550 shop manual.
Offline Geeto67
  • A grumpy
« Reply #12 on: December 04, 2008, 11:44:16 am »
check your charging system and make sure there are no other problems with the bike. That when you you put it back together and it is not charging or something else is wrong, you know to check the things you touched first.
Maintenance Matters Most
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #13 on: December 04, 2008, 11:47:09 am »
The cam you are looking at using wont require stiffer valve springs, but it won't hurt to replace old tired ones.
Tha'ts a fiarly hot cam. It probably can't do what it was designed to do without at least either increased compression (the sohc's are low compression bikes, 9.0:1), increased flow by having some headwork done, or both. A hot cam without these other things done is kind of useless, though I've heard the stock 650 cam in the 550 wakes it up a bit.
You could take the money you were going to spend on CR carbs and give to MReick to have him do a stage 2 port and polish. He can do a serdi valve job for you while hes at it.
If I were you, for the money, I would
1. Have MReick do a stage 2
2. Have MReick do your valve job
3. Have MReick deck the head to increase compression without having to buy expensive pistons
4. Buy cometic thin head gasket to increase compression a little more
5. Buy a 650 cam off of ebay
6. Rebuild your carbs and jet them accordingly
7. Find an exhaust that compliments these changes
These 7 things will give you a nice, rounded, reliable engine with a healthy increase in power across the rev range. At a reasonable price.
No.
Offline pablo78cb550
  • mmmph.
« Reply #14 on: December 04, 2008, 12:14:30 pm »
run sea foam through your crankcase. then drain the oil.
this will help loosen and remove dirt in the engine.
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #15 on: December 04, 2008, 12:17:15 pm »
I'd never put additives in a bike with a wet clutch. Just my opinion.
Not unless you are replacing your clutch.
No.
« Reply #16 on: December 04, 2008, 01:39:52 pm »
cheers.
the 75 550 doesn't have cam towers ...
see
Offline ieism
« Reply #17 on: December 04, 2008, 04:01:16 pm »
Bigger carbs are probably not going to make a huge difference on the 550's. Like they said, get the head ported instead, and spend the money on something else.
So you're running velocity stacks, but what exhaust do you plan on using? Maybe you can get some more HP with a freeflowing exhaust?
---cb550---
Offline Tim in Ohio
« Reply #18 on: December 04, 2008, 06:42:04 pm »
$200 bucks for a carb rebuild?  Naw.  For my CB350F rebuild, I got 4 carb kits for $20 each.
You mentioned before that you were thinking about tearing into your transmission... if you have the guts to do that, then surely you can handle a carb rebuild yourself.  If you don't have one, get a manual... also study posts on this forum.  As far as do-it-yourself bike procedures go... I consider a carb re-build to be a "Jessica Alba"...   (EXTREMELY do-able).
« Reply #19 on: December 04, 2008, 07:34:35 pm »
i also think the carbs are extremely do-able
Offline d3buttz
  • More than just an
« Reply #20 on: December 05, 2008, 02:36:30 pm »
this forum keeps giving me more ideas! ack! what about the 650 cam and 600cc ninja pistons? to much cost/work?
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1972 Datsun 240z
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #21 on: December 05, 2008, 03:07:51 pm »
22K and your bike is tired? I guess it could be if it sat too long but you would probably have a lot more leaking. I had some clicking on my 750K3 and rough idling recently (thought I would have to tear it apart also) and eventually found that my spark plug wires were ate up and my carbs were way out of synch (I originally synched then with the old pods on and changed to the old airbox). Clipped the wires a little and synched the carbs with the airbox on and voila! Can hit a ton easily and idles a lot better. Go through the procedure of a tune up first and check your spark and charging system like what was previously said (check compression also). If ya got the time and money for the teardown go ahead, but I don't so I won't quite yet.
Offline ghost
« Reply #22 on: December 05, 2008, 05:05:36 pm »
if it was mine, i'd start with a 650 cam, have your head ported of corse, then maybe some ninja carbs and a quality 4 to 1 exhaust. that'd really wake it up. anything more than that i'd probably look into a more modern bike. that's just me though.
« Last Edit: December 05, 2008, 05:09:51 pm by ghost »
Offline d3buttz
  • More than just an
« Reply #23 on: December 05, 2008, 07:00:52 pm »
you guys are great-thanks for all the advice-the 650 cam and headwork seems like the best way to go for the internal motor work thats on the cheap. once again-thanks!
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1972 Datsun 240z
