Author Topic: replacing carbs rubber tubes?  (Read 1264 times)
Offline cbr-eric
« on: December 04, 2008, 05:01:27 am »
so since they aren't available any more, what do you guys use??  just rubber fuel line?  any links for a place to get some nice durable stuff, or just hit up the local hardware store?  thanks a lot, dying to get this thing running WITHOUT the fear of needing a fire extinguisher ;)  do you think silicone line would hold the gas and not deteriorate? I use to use that stuff as vacuum line on my old turbo saab....
k8 project, a long way from done.....
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: replacing carbs rubber tubes?
« Reply #1 on: December 04, 2008, 05:12:32 am »
For the fuel pipe, standard automotive 5.5mm i/d 10mm o/d pipe is best.
The 6mm i/d 10mm o/d works as well (and is a lot more common)
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline cbr-eric
« Reply #2 on: December 04, 2008, 05:25:41 am »
thanks! and that is the same for all the rubber hoses between the carbs? thanks a lot, some of mine are so hard and.... melted it is hard to tell the size!! thanks again!
    • TVAM
« Reply #3 on: December 04, 2008, 08:31:24 am »
I think that's the same.
There's another post on here somewhere asking about the overflow pipes - they are different!
SOHC4 Member #2393
2015 Tiger 800 XRT
« Reply #4 on: December 04, 2008, 09:07:56 am »
They are available! Honda dealers sell them....plenty of other places as well -David Silver Spares, Bikebandit, ServiceHonda etc etc
cheers
Andy
Offline goon 1492
  • Sucka Repellant
« Reply #5 on: December 04, 2008, 09:35:52 am »
I'm confused  ??? do you mean fuel line, or the carb boots that go between the carbs and motor, if its the second you might check hondapartsdirect. I got my new jazzy velocity stacks from there, they are what goes into the airbox and attach to the ends of the carbs. They are nice and flexible too ;) :D
Offline cbr-eric
« Reply #6 on: December 04, 2008, 04:31:57 pm »
the 4 small diameter lines going between the carbs.  I had already looked on bikebandit and others and they are not available.  got some fuel line today and it should work great :)  at least it won't catch fire again (quickly knocks on wood!!!)  thanks guys!
Offline gonzobrian
« Reply #7 on: December 04, 2008, 04:46:24 pm »
I just ordered a set for a 69 KO from western hills honda a few weeks ago.
Edit:  I guess your talking fuel lines and not the boots.
« Last Edit: December 04, 2008, 04:48:13 pm by gonzobrian »
Offline cbr-eric
« Reply #8 on: December 04, 2008, 06:11:20 pm »
yuppers, fuel lines for sure :)  it's why it had a nice quick flash fire in the first place!
Offline Bodi
« Reply #9 on: December 04, 2008, 06:41:19 pm »
Hobby shops dealing with fuel engine powered cars or planes have small diameter fuel line that is the correct size for these connector hoses. It is a silicon compound, and generally comes only in bright "neon" colours. After a long soak in gasoline it doesn't show any degradation, plus these hoses are really only vents anyway and don't carry fuel. Sonce they are between the carbs they are not visible with the carbs mounted so the colour not a problem IMO.
Offline Tim in Ohio
  • So I got that goin' for me, which is nice.
« Reply #10 on: December 04, 2008, 07:01:12 pm »
I went to my local Honda Dealer and ordered fuel line as well as carb overflow lines.  I had to educate the parts counter guy to the fact that he was indeed able to order it from Honda.
1973 Honda CB350  Four
Check out my CB350F resto project...  watch a complete moron build a bike in front of your very eyes!: http://forums.sohc4.net/index.php?topic=38903.0
