Author Topic: CB 750 Rear Sets  (Read 15885 times)
Offline Chester345
  • will someday be an...
  • 76 CB750F
CB 750 Rear Sets
« on: December 04, 2008, 07:31:40 AM »
Hi all, looking for some pics or ideas for rear sets.  I've been digging thru the forums and now am wondering if anyone out there has fabricated anything themselves they are particularly proud of?
I've considered using the Dennis Kirk frame clamps with some late 90's CBR front sets and cutting the passenger peg part of the frame completely off.  Also considered some universal rear sets but I'd have to fab more linkage and those dang things are expensive.
Buddy of mine, good welder, wants to fab something up actually using the rear stock peg holes and making something to push back up on the piston for the right side with a new lever.  The left side is simpler imho, I'll just model what we do on the right.
Any ideas or pics of something that hasn't been posted already would be greatly appreciated!  I'm still in the thinking part of it...
Thanks!
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: CB 750 Rear Sets
« Reply #1 on: December 04, 2008, 07:35:40 AM »
These where made for my 550, but the concept might work on the 750 as well.
http://forums.sohc4.net/index.php?topic=27159.60
FJ
Offline Chester345
  • 76 CB750F
« Reply #2 on: December 04, 2008, 07:54:28 AM »
Very nice!  You go the whole 9 yards with fabrication!
I would love to do something like that... (translate, I'd love to have the tools to build that!)
Offline Steve F
« Reply #3 on: December 04, 2008, 09:43:52 AM »
Here's the brake side
Offline Chester345
  • 76 CB750F
« Reply #4 on: December 04, 2008, 11:11:05 AM »
That's nice, I like how you re-used a lot of the stock mechanism.
Did you machine that bracket yourself?
Edit:  I've come back to this about 10 times to drool over Steve F's peg mount, dang that thing is shiny!
« Last Edit: December 04, 2008, 06:16:59 PM by Chester345 »
Offline dusterdude
« Reply #5 on: December 04, 2008, 01:12:17 PM »
man thats purty
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Ricky_Racer
« Reply #6 on: December 04, 2008, 05:22:05 PM »
Okay, has anyone found arms from a stock bike that will fit the CB750 shifter shaft and the standard mechanical brake linkage shaft?  I checked on the brake side for a Tarozzi and they wanted $80 just for the aluminum splined arm!  Anybody found one that will work other than cutting and welding a stock brake pedal arm?  Thanks!  RR
Offline Bouncer
  • "Bear Down"
« Reply #7 on: December 04, 2008, 05:28:38 PM »
MORE info Please? Those are spectacular.  :o
New to the game.
1981 CB650C (Finished) Rat Bike
1978 CB750F Project "Bear Down"
Offline bigsherm
« Reply #8 on: December 04, 2008, 06:00:49 PM »
Ricky Racer,
     I'm pretty sure almost any Honda (as well as other Japanese brands) shifter arm will fit on the CB750 shifter splines.
     I went to the Honda dealer and asked if I could look in their parts for a shorter shifter arm.  They let me look in their bins, and I ended up using a Z-50(minibike) shifter, mounted backwards for an upside-down shift pattern.  It was very cheap.
     I would take your shifter off and to the parts counter with you, along with a measurement of how long you need the new one to be, and ask the same thing.  Maybe ask the parts guy if you can buy him a soda for his trouble, too.
     I'm planning my rearsets for my current project, and for the brake side, the footpeg will mount just aft of the brake pedal pivot.  I'll either shorten the brake pedal and the brake rod arm on the back side of the brake pedal shaft, or cut the brake pedal and drill it to use it as part of a linkage.
Sherm
« Last Edit: December 05, 2008, 06:33:29 AM by bigsherm »
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #9 on: December 04, 2008, 07:28:34 PM »
i still have to get around to making mounts and linkages for these, but here are mine in basic form. 100 bonus points to whomever can guess where i stole the design from...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline Steve F
« Reply #10 on: December 05, 2008, 04:48:47 AM »
Here's the shifter side.  I machined all the stuff myself, using mostly scrap that was laying around.  I made my own splined parts too
« Last Edit: December 05, 2008, 06:33:11 AM by Steve F »
Offline Steve F
« Reply #11 on: December 05, 2008, 04:50:54 AM »
This is the brake splined part that I made, using the stock splined shaft, which was shortened by about an inch. (sorry about the blurry pic)
« Last Edit: December 05, 2008, 04:52:29 AM by Steve F »
Offline Bouncer
  • "Bear Down"
« Reply #12 on: December 05, 2008, 03:30:56 PM »
Hmm interested in making me a set for some $? I live in chicagoland. I don't have the resources to make anything myself and have been contemplating a late model bike set modified but honestly don't feel I have the know-how to do that sort of thing. I'm a grease monkey, not an engineer. Ha!
New to the game.
« Reply #13 on: December 06, 2008, 07:45:45 AM »
Meeee, too.
Offline Flying J
« Reply #14 on: December 06, 2008, 10:59:41 AM »
I bought some R6 parts to build mine but if the price is right id be intrested too.
Offline d3buttz
  • More than just an
« Reply #15 on: December 07, 2008, 01:30:59 PM »
hey guys-i cut off the passenger pegs and i took a 1/4 inch flat plate steel, welded up both sides and drilled the i.d. for the tarzzozzi rear sets- they were pretty cheap(160$ i think) and i havent had any problems since-but it took ALOT of planning to have it comfortable,have the kick starter clear, have the brake still work-luckily the honda 550 brake arm on the wheel can be flipped to the top w/no mods.  my advice is to keep in mind all your variables-i was lucky after i was done that the original brake light switch and switch frame mount still worked in-line on my rear sets.
« Last Edit: December 07, 2008, 01:44:48 PM by d3buttz »
http://forums.sohc4.net/index.php?topic=80508.0
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1996 Nissan pathfinder
1972 Datsun 240z
2002 Nissan sentra se-r spec-v
billybobobrain
« Reply #16 on: December 07, 2008, 02:14:22 PM »
Hey that’s exactly what I’m in the middle of right now, looks great. Glad to know I’m not a kook.
« Reply #17 on: December 07, 2008, 04:08:29 PM »
debuttz,
Very nice looking!  What year/model CB750 do you have?
« Reply #18 on: December 07, 2008, 04:15:41 PM »
debuttz,
Tis a 550.
And I agree.
Question, by putting the brake arm on top you have switched the leading shoe/trailing shoe. I don't think it'll make a difference but have you tried the brakes out yet?
Someone else here with expereince probably knows.
« Last Edit: December 07, 2008, 04:18:01 PM by MCRider »
« Reply #19 on: December 07, 2008, 05:13:32 PM »
The shoes are indentical anyway, but the leverage will be reduced. Then again it's only a rear brake!
« Reply #20 on: December 07, 2008, 05:18:35 PM »
That's right my bad, the leading shoe is still the leading shoe. And the leverage issue may be for the good. Won't know till he tries it.
Offline d3buttz
  • More than just an
« Reply #21 on: December 08, 2008, 03:22:30 PM »
the brake arm lever on the wheel works like a cam-as you brake the lope becomes wider and pushes the pads out.  the lope is the same when yuo flip it 180'- the splines on the shaft have 1 wide spline that doent allow you to just flip the lever externally-but its super simple to do.  Also  the leverage is pretty good-i can lock up the wheel if i get on it pretty hard-not as great as stock tho, that arm stock is pretty long.ive had a couple of jerks oncoming make a fugazi left at intersections on me and im still here!
i recommend using the stock rod that connects the lever to the arm-its made of a hard steel with a high tensile strength.
also the nice part of using the tarzzozies is you can get the sets with folding pegs(what i have) and it makes it Alot easier to plan the placement in respect to the kick starter. flip and kick!
« Last Edit: December 08, 2008, 03:32:13 PM by d3buttz »
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1972 Datsun 240z
Offline Chester345
  • 76 CB750F
« Reply #22 on: December 09, 2008, 07:20:11 AM »
Man, I've got nothin.  I was goin over everything I could think of, Tron to Judge Dredd.  I do like the shape though, adds some artistic flare!
Thanks for all the replies and pics, awesome work, really!
Offline papp101
« Reply #23 on: February 08, 2009, 08:18:53 PM »
Any updates on this? Love the build!
Offline Flying J
« Reply #24 on: February 08, 2009, 08:53:52 PM »
I see a lot of K's with rearsets but the F bikes are a little more difficult with the rear disk and all the crap bolted to the side. Here was my solution.
