Author Topic: Exhausting question...  (Read 672 times)
Offline katmol
« on: December 05, 2008, 06:39:50 am »
I've got a '74 750k I'm bringing back to life this winter. The exhaust is shot. All four rusted through and through. I can get up a complete set of stock '78 750K pipes and mufflers from a guy close by. Can they be made to fit on my '74?
'74 CB750K Tracy Project
'76 "Modified" GL1000
'77 CB750A Blue
'77 CB750A Red
'79 CM400A Hondamatic
'81 CM400A Hondamatic
"Gone but not forgoten."
'76 CB750A Muscat Green
'70 CL450 Scrambler
'72 CL350 Scrambler
'75 CB750K Stock
'78 750K Black Dresser
Offline GammaFlat
Re: Exhausting question...
« Reply #1 on: December 05, 2008, 07:04:26 am »
The '78 pipes fit differently in two ways (from pre-77).
The way they attach to the head is different.  This one is easy to resolve.  77 and 78s have studs at the exhaust port.  A flower with 2 holes slides over the studs (with inserts pressing the pipe in).  pre-77 has a piece (flange?!) with 2 screws holding it to the head - the pipe slides over the flange and gets "clamped" to it.  The head is the same.
The other way they're different is way they attach in the back.  77/78 pipes seem to sweep upward more and the footpegs in the back of a 77 and 78 are in different spots (77/78s are higher).  The back of the pipes attach to the footpeg.  Earlier ones, directly, later ones with a bracket.
It seems hopeless for you so the 78 pipes should go to me, right?  :)  I really need a set.  ;)
If you're going aftermarket, the bracketing issues are less of a problem.  I may be doing the ones from Cyclexchange (black 4-2-1).
« Last Edit: December 05, 2008, 07:11:54 am by GammaFlat »
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
