Author Topic: Bad Idea I had Once  (Read 720 times)
Offline gerhed
Bad Idea I had Once
« on: December 06, 2008, 07:07:42 AM »
Had a lot of extra bike parts around (still do)
and I thought braking at the motor would be cool.--Looked cool , anyway.
Lovejoys and disc are kept from turning by
one keyway each,.
Keyway on the disc stripped out on initial run--creating a problem !
          83 XL600R in CB360 Frame
Offline mystic_1
  • 1970 CB750K
Re: Bad Idea I had Once
« Reply #1 on: December 06, 2008, 07:46:22 AM »
Heh, yup way too much torque for that sort of thing.  Nice try though :)
mystic_1
- John Augustus Shedd
Offline Soos
« Reply #2 on: December 06, 2008, 09:00:35 AM »
I would recommend a solid shaft from the lovejoy to the disk brake.
Don't you have a lathe tucked away with that little(302?) dream under your workbench?
What is this setup off of?
Is that your rail rider?
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline gerhed
« Reply #3 on: December 06, 2008, 09:54:21 AM »
l8r
Brake experiment was on an early version (longer & lower) of my tilting
electric 3-wheeler.
Offline bender01
« Reply #4 on: December 06, 2008, 10:15:40 AM »
That thing looks cool. Is that a saw handle for a lever? Post some pics of it please.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline gerhed
« Reply #5 on: December 06, 2008, 10:53:54 AM »
Yes, saw handle on the tilting tiller.
Right hand tiller steered it.
Disc brake didn't stop it !
Headlights turned with the wheels, of course.
« Last Edit: December 06, 2008, 10:58:48 AM by gerhed »
Offline tramp
« Reply #6 on: December 07, 2008, 07:44:53 AM »
wheels are easier to brake because if you press to hard they just lock up
brake at the motor and there is alot more torque
1974 750k
