Author Topic: cb750 supersport gas tank  (Read 1135 times)
Offline jakecb420
« on: December 07, 2008, 07:12:49 AM »
i was wondering if honda used the same tank shape for the supersport from 75 to 78? the tank is one the key ingredients i need for my f model, if its the same tank, then it will open my options up a bit. thanks.
750K3 daily driver
76 750F project
74 CB450 donor
79 50cc honda express 2 moped
73 cb500-4
http://forums.sohc4.net/index.php?topic=73724.0
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
Re: cb750 supersport gas tank
« Reply #1 on: December 07, 2008, 08:20:32 AM »
The physical tank shapes are the same. The petcocks and petcock mounts are different between the 75-76 F1's, and the 77-78 f2's.
« Last Edit: December 07, 2008, 08:44:04 AM by cafe750 »
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline shoemanII
  • just another bike nut
« Reply #2 on: December 07, 2008, 09:06:59 AM »
i asked the same question, see december 4 post and answers for lotsa info. ;)
bobp
'96 ducati carb'd 900ss/cr
'72 dt2
'77cb550k frankenberry:  '77cb550k frame, '78cb550k engine, '78cb550f tank, unknown front-end
