Author Topic: 400/4 1976  (Read 1194 times)
Roly
« on: December 07, 2008, 10:01:35 AM »
I have just bought my first Honda SOHC/4 a 1976 400/4, in fair condition. It starts & runs ok with just a little rattle at the top end. However when I ride off a loud whine develops, which stops if I pull the clutch in. I know this a bit vague, but it's diffficult to pin-point exactly where the noise is coming from when riding. It doesn't do it when in gear on the mainstand. Has anyone any ideas? I know I should have ridden it before buying, but I was a bit too trusting, thanks for any help, regards from England, Roly
Offline dave400
  • Super Lamb Banana
Re: 400/4 1976
« Reply #1 on: December 07, 2008, 11:13:20 AM »
Mine makes a whining noise when I ride it and has done since I’ve owned the bike.
Cheers
Roly
Re: 400/4 1976
« Reply #2 on: December 07, 2008, 11:59:51 AM »
This is a really loud whine, unlike anything I've heard before. My gut feeling is that a bearing is to blame, Roly
Offline wizzy
Re: 400/4 1976
« Reply #3 on: December 07, 2008, 01:09:27 PM »
I had a cb500 that had a wird whining noise to it, come to find out after trouble shooting it was the tach cable was not lubercated and made a whine only above a certin rpm. again didn't here it when it sat to warm up at idle, only heard it while riding.
"They didn't make me captin because I could sail"
Roly
Re: 400/4 1976
« Reply #4 on: December 08, 2008, 10:03:12 AM »
I ran it in first gear with the bike on its stand, then put a slight load on the transmission by applying the back brake gently. This induced the whine so I got a friend to use a screwdriver as a "stethescope" and the noise does appear to be coming from the clutch area, or perhaps a gearbox bearing behind? I shall dismantle the clutch and see what I can find, hopefully nothing too bad, any other ideas?,
cheers, Roly
