Author Topic: Repair of bent steering stop  (Read 1935 times)
Offline markjenn
  • CB750K1, CBX, RC30
    • Whizmo and Gizmo
« on: December 09, 2008, 12:09:36 PM »
The left side steering stop pin on my CB750K1 lower triple clamp is bent which is causing some minor fouling of the right fork cover with the tank when the handlebars are full lock right.  (I missed this during my rebuild or I would have fixed it.)  I'd guess the pin is bent perhaps 10-degrees or so.
If I try and hammer it back straight "in situ" am I likely to snap it off?  Take it off and bend it back with heat?  Shim it?  Your recommendations please.
- Mark
Offline Clyde
Re: Repair of bent steering stop
« Reply #1 on: December 09, 2008, 04:47:43 PM »
This happened to one of my triple clamps.I used heat to get it right.
On another triple clamp the steering stop had snapped off altogether, so I made a steering stop with an 8mm thread on the end. I then  drilled and tapped a 8mm thread in the triple tree and brazed it in place. Still there 7 years later
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline markjenn
    • Whizmo and Gizmo
« Reply #2 on: December 09, 2008, 08:13:49 PM »
Thanks for response.
The bike is reasonably stock and nice, so my first inclination is to do this, but after taking the front end apart to get the bottom triple off, I'd hate to end up snapping it off.  With a propane torch for heating, am I likely to get it straight without having it break?
I can shim (or drill and tap it with bolt as you suggest) in-situ and nobody would know any better, but if I can get it right, I'd prefer the bending approach.
- Mark
Offline Clyde
« Reply #3 on: December 09, 2008, 10:51:15 PM »
I used oxy/propane but oxy/acetylene would be as good or better.
You need to get it red hot.
SOHC4 #1909
« Reply #4 on: December 09, 2008, 11:08:15 PM »
Or bend it till it snaps off and weld it back on
