Author Topic: midnights college budget build.....(updated:02/18/2010)  (Read 27801 times)
Offline J.Webster Designs
  • www.JWebsterDesigns.com
« on: December 09, 2008, 04:38:13 PM »
Hey guys, I am relatively new here. I recently bought a CB750F that was as termed by a member to be a "Bitsa." The bike is a 1976 CB750F with a 1978 CB750K motor in it. One of the original owners did a four corners ride and blew the original motor out and replaced it with the 78. The carbs are from the 76 F and various other things were swapped with 78 parts.  The bike was bought as a non-runner for $450. The non-running part was quickly fixed the day after buying it. However, I was having idle problems that are possibly due to carbs. So in that spirit, I decided it would be a good bike to do the whatever I wanted to do to it as it doesn't hold any value as a numbers matching bike.
The plan (now):
- I am currently in college and away from home where all my metal working tools are. (grinders, welders, plasma cutter, acetylene torch, etc..) So for the time being the bike will be getting a once over and all the parts cleaned up. I will be doing a top end build on the motor and carb rebuild so that the bike is ridable and looking better than when it was bought. I will be making my own seat, adding clip-ons, upgrading the master cylinder to a newer model one. (my master cylinder is leaking like a faucet and have heard horror stories of rebuilding them). Stainless braided brake lines will be added ( mine are rotted and cracked). as well as doing some other little touches that will make the bike look better.
The plan (future)
- Completely tear down the bike for a second time and do a complete all-inclusive build on it. I will chop all unnecessary brackets off the frame as well as weld in new bracing. I plan on upgrading to either a CBR100RR or R1 front end including brakes. I will also either adapt a Rear end off of one of those bikes or make a new rear end to utilize the wider set up and braking. Wire wheels will be fitted to keep with the theme. Once the frame and suspension is take care of the engine will receive a COMPLETE rebuild. I am still up in the air if I want to do a complete hotrod engine (836 kit, lightened crank, CR carbs, cam, flow the heads, etc.....) or do a mild build. I am leaning towards the hotrod engine to go with the suspension. Once that all is done I will do lots of body mods. I will make my own seat pan, rear fender, front fender out of carbon fiber And will do a carbon fiber overlay on the tank. These parts will not be bare carbon, they will be painted with some carbon showing through in some pattern. Other things will be added to the list once I start riding it and figuring out what I want to change on the bike.
I have worked on cars my entire life but this is my first build on a bike. I will be looking for help from you guys when I run into a problem with part interchangeability and just help in general. I look forward to sharing the first "college budget" build with you guys and eventually sharing the "all-inclusive" build with you all.
Let the picture posting begin.....
How she looked when I bought her.....
The problem....
The teardown...
My new favorite tool...
I am currently on the cleaning and reassembly process. I will get some pictures up later of the cleaned up frame and where it stands right now. I have to order order my carb parts (hondaparts-direct) and top end gasket set (Cycle-exchange). I will be going home for the winter break so progress will come to a halt until I get back on the 5th. hopefully I will have the gaskets and parts ready to go when I get back and I will get her together quickly once the motor is together.
Tell me what you think.  Cheers!
« Last Edit: February 18, 2010, 08:16:22 PM by midnight08 »
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
Re: midnights college budget build.....
« Reply #1 on: December 09, 2008, 05:29:26 PM »
here are those pictures....
This is what my girlfriend has to put up with....
VISIT OUR WEBSITE!
Facebook:
Instagram:
lukedeisel
« Reply #2 on: December 09, 2008, 06:12:20 PM »
This build should be sweet! This is very similar to what I have done in the past and am doing now. I look forward to seeing it progress.
« Reply #3 on: December 09, 2008, 07:45:05 PM »
the "college budget" one will be a nice looking bike but will not be the full on "all-inclusive"  build that i have planned for the bike. i wish i had all my stuff here so that i could just build it the way that i want to. some times you cant have everything you want.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline volkswagendan
  • im a bit off the charts. sorry.
« Reply #4 on: December 09, 2008, 08:58:26 PM »
sweet. keep up the good work.
« Last Edit: December 09, 2008, 09:00:35 PM by volkswagendan »
don't take me too seriously.
Offline BlindJoe
« Reply #5 on: December 09, 2008, 09:13:27 PM »
As far as the high idle...it's probably air leaks around the carb boots
Offline DarkRider
« Reply #6 on: December 10, 2008, 02:00:28 AM »
Sweet build gotta ask though What was the red bike shown in one of the pics? Also just a suggestion why not look at running a GSXR front end on this? Take a look at Squirleys build on here. He used a Gixxer front end and an HD hub and was able to run spokes and have modern suspension and braking with not that much work as compared to doing an R1 front end.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
« Reply #7 on: December 10, 2008, 07:33:02 AM »
That was another idea that i was given. the carb-head insulators will be replaced hopefully fixing that problem.
Dark rider... that is exactly what I am looking for. I have been doing research on what front ends swap the easiest. I didnt know that the GSXR front end swapped easier. I will take a look at squirleys build and see what he has going on.
as for the red thing in the background..... that is my ride to classes.
40mph - 85MPG and pretty dang fun to flick around in the corners due to its low weight. It will be getting a big bore kit sometime next year probably. should do around 50-60
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline kmart550
« Reply #8 on: December 10, 2008, 07:44:12 AM »
Good luck with the build.  As a fellow college student and bike builder it does take time.  It usually seems when I have time to work on the bike I have no money, and when I have money I have no time!  Looking forward to watching your build.
77 Honda 550 "Bobber" Daily Driver/Project bike.
"Do not go where the path may lead, instead go where there is no path and leave a trail."
« Reply #9 on: December 10, 2008, 08:50:21 AM »
I hear you on that Kmart.... Its going to be a little while before i get all the parts I need to do the build. so I want to have a bike that looks good and runs good to hold me over till then. Not to mention that when you ride or drive something and you are thinking about modifying it you always think of things that you wouldn't have when you are riding it.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline rachet
  • '77 CB750 F2
« Reply #10 on: December 10, 2008, 09:58:45 AM »
I love watching the creativity of poor college students!  It's looking great, keep it up.
Rachet~
But I need Tacos!  I need them or I will explode!
« Reply #11 on: December 10, 2008, 01:21:35 PM »
we can have some pretty creative minds when there is necessity.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline bzr
  • I'm not here.
« Reply #12 on: December 11, 2008, 06:49:26 PM »
Another broke-ass college student for the win! And I agree, the cheap impact driver has saved my life and sanity countless times.
Good luck with the rest of the project!
1976 Honda CB550F
« Reply #13 on: December 11, 2008, 06:59:32 PM »
thanks BZR. I'm ordering up my parts for the motor and carbs. when i get back from winter break things should start to move more quickly.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« Reply #14 on: December 11, 2008, 07:33:54 PM »
When I got my 750 running for the first time I couldn't get the idle down. I believe the carbs were running out of gas and was pulling air in through the bowl vents due to a stopped up petcock.
But I noticed as soon as the idle hits 2000rpm it jumps waaay up, I think because the spark is advancing.
You may want to check and see if the spark advance is stuck or sticky.
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
« Reply #15 on: December 12, 2008, 07:25:30 AM »
forgot to add that i pulled the ignition cover and found dyna ignition already installed. as well as 3 ohm coils.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline DarkRider
« Reply #16 on: December 12, 2008, 07:28:49 AM »
Now that is a sweet find. Take this as you may...but i think that bike would look great if it was redone in the same paint scheme as you got it. Perhaps replacing the neon green with british racing green with the white stripe down the center.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
« Reply #17 on: December 12, 2008, 10:28:51 AM »
i cant pull my self to do it. its going to be mostly black. when it gets the money put into it that it deserves it will be black with carbon fiber showing through and red accents breaking up the transition.
VISIT OUR WEBSITE!
Facebook:
Instagram:
« Reply #18 on: December 14, 2008, 06:10:52 PM »
freshened up the foot pegs to hold me over till i get rear sets....
Here is how the frame sits right now. I know that its a crappy background to take pictures against. ill take some new ones tomorrow....
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline Bouncer
  • "Bear Down"
« Reply #19 on: December 14, 2008, 06:27:58 PM »
Looks good man, keep it up. I also am a former college student, but I didn't have a garage. I had to haul my dirtbike up the front stairs into the house I was in.... it sat in my bedroom ha ha ha. I probably have a pic of it in my bedroom somewhere around here. I can definitely relate to the time/money issue.
New to the game.
1981 CB650C (Finished) Rat Bike
1978 CB750F Project "Bear Down"
« Reply #20 on: December 14, 2008, 06:38:49 PM »
Thanks for the compliment.... I just recently got a garage so I'm a lot happier. I'm used to being back home where I have a huge 3 car garage, heat, exhaust vents, any tool you can think of at my disposal. I look forward to doing the full build and sharing it with you guys.
VISIT OUR WEBSITE!
Facebook:
Instagram:
crustyxpunk
« Reply #21 on: December 15, 2008, 01:13:25 PM »
I may be wrong but that motor looks like an F not a K since it is all black unless someone painted it or did honda start painting them all black?  Good luck with the build by the way, I'm also a poor college student trying to get my own project going.
« Reply #22 on: December 15, 2008, 02:47:17 PM »
can someone confirm that statement? the engine # is CB750E-3103-68
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline Bouncer
  • "Bear Down"
« Reply #23 on: December 15, 2008, 03:43:04 PM »
Here you go bud.
http://hondachopper.com/modifications.html
New to the game.
« Reply #24 on: December 15, 2008, 03:57:17 PM »
so am i reading this right? it should be a 78 K motor correct? if it was an F motor it should be CB750FE?
VISIT OUR WEBSITE!
Facebook:
Instagram:
