Author Topic: what master cylinder to use??  (Read 3176 times)
Offline tygrant
« on: December 10, 2008, 07:49:43 PM »
I was going to rebuild my master cylinder because it was leaking and was quite coroded inside. i thought i might update to a newer MC does anyone know what will work as far as just replacing it with a modern MC off a newer bike? i see some listed as "DUAL" caliper but does it really matter? i mean it will just be more sensitive if i have one designed for a larger brake system? am i correct in thinkin this? i found this on ebay and was considering it any input??
http://cgi.ebay.com/ebaymotors/FRONT-BRAKE-MASTER-CYLINDER-CB400-CB450-CB550-NIGHTHAWK_W0QQcmdZViewItemQQ_trkparmsZ72Q3a570Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem110323646244QQitemZ110323646244QQptZMotorcyclesQ5fPartsQ5fAccessories
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline pablo78cb550
  • mmmph.
Re: what master cylinder to use??
« Reply #1 on: December 10, 2008, 08:16:16 PM »
check out mikesxs.com
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Offline XN
« Reply #2 on: December 10, 2008, 09:03:08 PM »
I got that same master cylinder and it works great!
78 Honda CB750K
02 Yamaha V-star 650
02 Honda VTX 1800
Offline ev0lve
« Reply #3 on: December 10, 2008, 10:57:55 PM »
I remembered seeing a discussion of the piston size and it's effect on single and dual setups. Unfortunately, I'm not a hydraulic engineer but I buy the premise  ;)
http://forums.sohc4.net/index.php?topic=24856.msg255223#msg255223
Offline tygrant
« Reply #4 on: December 11, 2008, 05:43:43 AM »
XN, are you using it with a single or dual disc set up??
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline moham
  • .fnord.
« Reply #5 on: December 11, 2008, 06:00:14 AM »
I have seen that one on previous posts and also the one below. I think they are both 14mm piston. I, too, am curious about people's experience with these...
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline tygrant
« Reply #6 on: December 11, 2008, 06:15:25 AM »
i like the one that i posted mainly becasue i can run one SS brake line and get rid of the stupid pressure switch housing becasue it has the brake light switch built into it. the stock mc is also 14 mm correct?
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline lordmoonpie
    • Moonpie
« Reply #7 on: December 11, 2008, 01:23:57 PM »
Ooo go for this - it works amazingly well, looks like an authentic part of the time (well it was!) and you can bleed these up to get the lever rock hard! Great stuff....
http://www.apracing.com/info/products.asp?product=Classic+Front+Master+Cylinder%2DCP2215%2D90_2557_1875
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline edbikerii
    • Gallery
« Reply #8 on: December 11, 2008, 01:42:13 PM »
I got the same one, and it works fine.  There was no real improvement in firmness or feel, but it does potentially simplify the hose routing since you can remove the pressure switch and the associated block, and run a straight line.  It is sometimes difficult to bleed the block.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline KB02
« Reply #9 on: December 11, 2008, 03:32:58 PM »
Yeah, I had that same one on my F1. It worked.  :-\  I was hoping for a little better feel or power but got neither. It worked. That's about it, really.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline moham
  • .fnord.
« Reply #10 on: December 11, 2008, 04:20:58 PM »
lordmoonpie: cost on that ap product?
78 750K-The Ocho
Offline XN
« Reply #11 on: December 11, 2008, 10:57:22 PM »
Single right now... working on a dual setup for next summer... Like the others said it works fine no huge change from the stock one. Biggest thing for me is my stock one had road rash and leaked so for a few $$ more than a seal kit I got a bran new master.  :P
78 Honda CB750K
02 Honda VTX 1800
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #12 on: December 11, 2008, 11:34:00 PM »
That picture you posted is a radial MC.... Little different configuration but is commonly used in hi-po applications. I used one on my drag bike and it seemed to withstand anything I could throw at it.
Then again for almost $300+ new they better.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline lordmoonpie
    • Moonpie
« Reply #13 on: December 12, 2008, 04:18:41 AM »
From memory it's about £240 - $360 USD
1994 Ducati 888 SP5
Offline moham
  • .fnord.
« Reply #14 on: December 12, 2008, 06:30:15 AM »
Thanks for the clarification, I didn't know the manufacturer (I be ignorant) and read up on the radial MCs. The site below has a nice explanation as well as many great looking levers...You're right, tho, taint cheap!
http://www.oppracing.com/pages/articles_brembo_master_cylinders/
78 750K-The Ocho
Offline lordmoonpie
    • Moonpie
« Reply #15 on: December 12, 2008, 03:08:35 PM »
No - it ain't cheap but damn it's good! One cast iron 290mm disc and one of these and I can get my old black bomber doing monster stoppies - superb!!
Just got one for my cb750 too but with the old honda calipers I can't bleed them up to be very effective. If I used the corresponding AP classic caliper though - awesome.
AP are a fantastic brake firm - been going for years in the UK and they are used on all the top performance cars  too.
1994 Ducati 888 SP5
Offline tygrant
« Reply #16 on: December 12, 2008, 06:15:47 PM »
they look like nice products, i think im going with the cheapo though, and a single SS line down to the caliper. considering i have a total of 700 into the bike+build 3 to 4 hundo is too much to spend. Thanks for the replys on the post, once again this board is the best
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline moham
  • .fnord.
« Reply #17 on: December 12, 2008, 06:25:29 PM »
Lord Moonie:
I was flipping through the calipers on the AP site and was having a hard time spotting the classic caliper...got a part no.?
78 750K-The Ocho
Offline HavocTurbo
  • Can you tell?
« Reply #18 on: December 13, 2008, 06:33:18 AM »
I scoured ebay looking for a radial MC that was cheap, average prices are around $175-$200.
Any modern MC with a remote reservoir should be more than enough to handle the old caliper(s). GSXR,CBR,ZX.... any of those will work.
Then all you have to do is find a year with a cable draw clutch perch that matches the lever on the MC.
09 XL883L - No Name
Offline lordmoonpie
    • Moonpie
« Reply #19 on: December 13, 2008, 08:55:39 AM »
Sure thing - CP2215. Go to the main apracing website then click on motorcycle tab at the top right, scroll doen to select maser cylinders from the fly out menu and below the pictures on the right is another link to "classic master cylinders" or somehting like that.
Enjoy!  ;D
1994 Ducati 888 SP5
Offline moham
  • .fnord.
« Reply #20 on: December 13, 2008, 09:10:57 AM »
Enjoy!  ;D
Found that one no problem...but I was referring to your earlier statement with regards to caliper:
It's the caliper I was curious about. Thanks for the info so far. I think I see one of these in my (formerly low-dollar) 550 project.
78 750K-The Ocho
