Author Topic: 2 quick, daft questions!  (Read 1695 times)
Jim Shea
« on: September 28, 2005, 05:37:50 AM »
Should the petcock be turned to off when the bike is left overnight?
Should the engine be warmed up a little before riding?  Or does it damage the engine to sit for a minute or 2 to let it warm up?
Jim.
Offline Bob Wessner
  • "Carbs Suck!"
Re: 2 quick, daft questions!
« Reply #1 on: September 28, 2005, 06:25:41 AM »
I personally  turn off the petcock anytime I turn off the ignition. Some warming I think is a good before taking off, and a miinute or two is not too long. Usually I need to warm it longer than that, particularly during the cooler months.
Jim Shea
« Reply #2 on: September 28, 2005, 06:30:02 AM »
Thanks Bob.. I find if I warm it for a minute or so, the clanking noises stop, or at least diminsh!
Jim.
Offline Raul CB750K1
« Reply #3 on: September 28, 2005, 06:32:13 AM »
I have a feeling of some deja-vu...
Raul
Jim Shea
« Reply #4 on: September 28, 2005, 06:37:06 AM »
Sorry if these q's have been asked before... but I have gone to faq's and Greenspun archives, but searching through the thousands of posts takes forever!!
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: September 28, 2005, 07:11:00 AM »
Jim,
I've also found that that first clunky shift into first gear can be deminished if you hold the clutch in for a few seconds, then goose the throttle and then let it settle back to an idle, seems to free the clutch plates.
« Reply #6 on: September 28, 2005, 08:21:36 AM »
In my opinion, the FAQ section is better as a read than as a troubleshooter. If you read through it you will understand lots of things that are related one to each other. I was just joking, I don't think anybody here mind answering questions, but if you are as beginner as you say you are I believe you should first understand the whole picture and then make the questions. Otherwise the answers will probably generate new questions...
Raul
Offline hymodyne
« Reply #7 on: September 28, 2005, 10:13:05 AM »
yes, and yes.
hym
