Author Topic: swingarm needle bearing setup -on the cheap???  (Read 3379 times)
0 Members and 7 Guests are viewing this topic.
Offline crazypj
  • I'm brill, me
Re: swingarm needle bearing setup -on the cheap???
« Reply #25 on: December 15, 2008, 10:06:58 am »
Needle bearings are evil.....
If you use one way clutch needle bearings it's not so bad, reduces rocking grooves by forcing bearing to move in 1 direction only.
l8r
Wouldn't that make it a plain steel on steel high friction bearing on opposite travel?
PJ
Markcb750
« Reply #26 on: December 15, 2008, 03:58:06 pm »
l8r
PJ
Not so sure about this one???
What Bearing manufacturer/part number do you use?
« Last Edit: December 15, 2008, 04:28:15 pm by Markcb750 »
« Reply #27 on: December 15, 2008, 04:24:09 pm »
Swingarm, Needle bearings & Cheap, cant fit in the same sentence properly to answer the original question..
