Author Topic: back on 2 legs sorta  (Read 1124 times)
Rocking-M
« on: December 15, 2008, 07:44:26 AM »
Friday I got the news the bone could stand my weight.
That after 3 months of being off it. So I'm down to using one crutch and
walking as much as I can right now (doing some stair stepping to strengthen the leg up
a bit before more exercises)
I've got to get the range of motion back in my knee. I don't think my knee was blown out
in the wreck cause the Doc keeps saying I have scar tissue that I'll be stretching and working out.
Right now I can bend it to almost 90 degrees. Any suggestions on good techniques to be able to
get the knee to bend all the way back (preferable without bring tears to my eyes ;))
Offline azuredesign
  • Knupping pin
Re: back on 2 legs sorta
« Reply #1 on: December 15, 2008, 07:47:31 AM »
Would using an exercycle adjusted correctly so that when fully extended you were not in bad pain, using very light gearing help. As you progressed, you could increase the seat height for greater extension.
My $.02, and good luck!
Ben
Rocking-M
« Reply #2 on: December 15, 2008, 07:52:12 AM »
might be an idea, full extension doesn't hurt it's the bending that I lost motion with.
I suppose the only way I'll get it back is painful stretching, the wife said she'd help by
pushing on it till the tears start, then relax, then push again....  :o
Offline KeithTurk
« Reply #3 on: December 15, 2008, 07:53:39 AM »
Don't take a bunch of drugs to mask the pain and then take as much pain as you can stand....
Learn you limitations... and live on the edge of them....  but when you venture to Gray area's... be sure to be close enough to the known limits that you can still be worth a #$%* when you get back....
Like most of us... I've been twisted up fairly bad... ( helicopter lost a tail rotor once.. Bad year )...  it took me 3 or 4 yrs to learn the above...  First I took drugs and hurt myself badly... then I stayed a pussy for a while... then I started finding out what was left and using the stew out of it...  now 25yrs later I honestly don't feel much of it at all...  I'm fairly normal...
K
Rocking-M
« Reply #4 on: December 15, 2008, 07:59:12 AM »
Hey Keith, i never took the drugs they offered me and boy will they offer some stuff
when you get a little twisted up. Makes smoking reefer look like child's play.  ;)
I never have liked stretching over the years and now I'm having to and hating it more.  ;)
Reminds me of some sorta mid evil torture rack.
upperlake04
« Reply #5 on: December 15, 2008, 08:05:33 AM »
               Not quite 90 degrees won't work on the the rear brake. Good news is that you aren't out any real riding time this winter and there's lots of time to get it into shape before spring. :)
               I can see your wife helping by bending it till the tears start, then relax, then bend again,  thinking to herself 'when is the renovation going to be finished?', all the time sweetly smiling  "I love you Roberto"    ;D
Offline Uncle Ernie
« Reply #6 on: December 15, 2008, 08:42:23 AM »
Don't get too macho.  Pushing too hard, too fast can be detrimental too.  If it hurts too much, you start pushng back and resisting.  I'm afraid a lot of it is just time and consistancy.  Shoot for improvement, not especially "as before".
Keith, that "normal" thing sounds intriguing.  What is it?
Offline alltherightpills
« Reply #7 on: December 15, 2008, 10:29:38 AM »
This is obviously an extreme example, but...
My BFF crashed a 4 wheeler at 45 mph when he was 16.  Luckily a big pile of broken up concrete stopped him :o.  The crash broke his tibia, fibia, ulna, radius, elbow, humerus (all of these were compound fractures, which are the kind that poke through the skin), lost most of his kneecap (it was laying on the ground) and broke the bottom of his femur off.  If the ambulance showed up 5 min. later, he would have bled to death.  At the hospital that night, the docs initially said that they would likely have to amputate his left leg below the knee.  Then they said he would never be able to bend it, then they said he would never get more than 10 degrees of motion, then they said he would never get more than 45.
After a extensive rehab and physical therapy, he had full mobility of his leg in less than two years. He said the most painful part of the recovery process was when the physical therapist would have to break the scar tissue away from the ligaments and muscles so that it wouldn't immobilize the joint.  He also had to do a lot of reps with little to no weight to try and build up strength in his knee.
I tore 2 of the 3 tendons in my rotator cuff in 8th grade and part of my pt involved lifting soup cans.  They also did deep tissue heat, which helps relax the muscles surrounding the joint.  So stretching and a lot of reps with little or no weight were the keys to both of our rehabs.
Go to a physical therapist.  They will be able to help figure out what kind of exercises and stretches would be most beneficial.
78 550K
77 550K (in pieces)
71 500K0 (in pieces)
Rocking-M
« Reply #8 on: December 15, 2008, 11:14:03 AM »
thanks ATRP, makes my little bit of scar tissue seem like nothing.
The Doc who also sets up PT told me she felt I could handle it my self,
if not I happened to run into a local PTist just the other day and I'll give him a holler.
Hey Dave, I wondered why the nice wifey got that Nurse Ratchet look when the Doc
told her she could inflict pain on me.  ???
« Reply #9 on: December 15, 2008, 12:59:46 PM »
Can't give you any tips Robbie as I have never been there, what I would say is take Paul advice and don't over do it.
Pleased you're making headway.
Sam. ;)
Offline tramp
« Reply #10 on: December 15, 2008, 01:24:54 PM »
don't give up, keep using it and push a little more as you can bear it
1974 750k
Rocking-M
« Reply #11 on: December 15, 2008, 01:25:34 PM »
thanks Sam, hey we got mail all the way from England today, that mail man had a long swim.  ;D
« Reply #12 on: December 15, 2008, 01:44:06 PM »
Bloody fast swimmer Rob  ;D ;D ;D ;D
All the best Mate. ;)
Sam. ;)
Offline 736cc
« Reply #13 on: December 15, 2008, 02:45:57 PM »
 You will make progress but it takes time. I had a really bad wrist break 18 years ago and its a humbling experiance PT but it helps. Go to a PT at least a couple times and he/she will know the correct stretches and exercises. Plus you'll be exercising, always a good thing! It will take at about 8 months to a year before you get 75% of your range of motion, and you probably won't ever get 100% of it back. And it may be a year or so until you manage to do things w/o feeling like you have a encumberance. My wrist will never be the same but it ain't holding me back. And get back on a motorcycle sooner or later, you'll never regret it
Online Jerry Rxman Griffin aka MuthaF'er
« Reply #14 on: December 15, 2008, 11:44:46 PM »
90 degress is a good start. You have some things that will slow you down at first. Tight tendons and ligaments. Stretch slowly but progressively. Swelling. Until it's fully gone don't expect a full 180 degress. Less inflammation = more flex. Pain. It's not a bad thing so listen to it and only do what it tells you that you are capable of. I did light knee bends and I would also reach behind and lift my leg towards my ass without the weight on it. Access to a hot tub would be good therapy provided there are no open wounds. PT, which some think is physical therapy, is actually pain and torture but may be necessary. Those guys are really mean but good.
I did have one minor detail at first. After my ACL/MCL surgery I had a large cut on the inside of my knee. The cut got dirty/infected while in the cast the first week. Cast came off and antibiotics. My knee actually locked up and no matter how hard I tried to tell my brain to break the adhesions free my body said no way so it had to be "manipulated" past that 90 degree mark. The doc put me under and just grabbed it with both arms and bent it until the adhesions popped loose.
Takes time so just be patient. When you can reach back, pull your leg up and touch your ass with your heel you know you've done a goof job!
« Reply #15 on: December 15, 2008, 11:57:33 PM »
A hot tub is great for loosening muscle but don't forget to ice it if it starts to swell, this will help keep the swelling down and make your therapy easier.. ;)
Rocking-M
« Reply #16 on: December 16, 2008, 04:57:04 AM »
thanks for the input Jerry, I figured some of you all had gone through this,
by the way, how did you know I was a goof job.  ;D ;D
