Author Topic: CB550 ignition switch relocation  (Read 3720 times)
Offline FunJimmy
  • Who you calling
  • Vancouver
« on: December 17, 2008, 08:25:51 AM »
Will an early CB500 ignition switch bracket fit on a '77 CB550F?
Could someone post a picture of their switch and bracket so I can get an idea of how and where they fasten?
Anyone have an extra bracket they would be willinf to part with?
Thanks
Jimmy
Re: CB550 ignition switch relocation
« Reply #1 on: December 17, 2008, 08:42:31 AM »
No it wont unless you weld it on and if you did the switch wont fit so if you fit an earlier switch the loom wont fit.
Anything else?
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #2 on: December 17, 2008, 09:41:02 AM »
Bryan
That's not the news I was hoping for.
Thanks for it though.
FJ
« Reply #3 on: December 18, 2008, 01:06:30 AM »
Why do you want to move it? if the switch is duff parts are available
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #4 on: December 18, 2008, 01:09:00 AM »
Reconfigured the triple trees and the switch just stands out like a sore thumb.
Need to find a clean alternative to mounting on the top triple.
FJ
Offline cafe2be
« Reply #5 on: December 18, 2008, 05:17:53 AM »
I am doing the same on my bike as well. I am actually using the orig location on the triple tree to mount the new mini tach and speedo. The ignition will go under the seat. Not sure where yet. I am also changing the wiring on the bike to use less wires and only a on/off ignition switch.
« Reply #6 on: December 18, 2008, 06:29:00 AM »
If you take the loom, switch and bracket from a 500/550 72-76 (early 500 ones were a different loom) you should be able to transplant them but will end up with only 1 fuse and no starter safety circuit depending on year
