Author Topic: Steering Stem Torque ?????  (Read 3657 times)
Offline Jakoba
  • I'm far from a CB750
« on: December 17, 2008, 12:27:59 PM »
Just got finished replacing the Steering Stem Bearings in my 78 750K. ;D ;D
Cudo's to Hush and his awesomness in the thread "ALL BALLZ tapered steering bearings for non experts." ;) ;)
My only question is ....what is the Torque for the Steering Stem  ??? ???
Jako
Jako
Member #4500
"See the ditch, see the ditch, in the ditch"
Re: Steering Stem Torque ?????
« Reply #1 on: December 17, 2008, 01:17:55 PM »
Jako
Do you have a torque wrench attachment that will fit that 4 notch nut?
With the front off the ground, and preferable no cables or wires to interfere, I would tighten it down by hand, and then with a large channel lock type pliar to where turning the fork side to side feels a bit impaired. Also, a shock adjusting wrench may fit. Then loosen it a tad (1/4 turn or less) to where the fork moves smoothly and continue the reassembly.
You may need to tighten it again after riding as they may seat themselves after hitting a few bumps.
I'd be interested in others procedures.
Offline scondon
  • Mmmm......tasty bugs
« Reply #2 on: December 17, 2008, 01:47:15 PM »
  For the outer chrome steering stem nut the torque is 57-86 ft/lbs. Always be sure to loosen the upper tree pinch bolts before torquing this down(if forks are installed) so that things don't get cock-eyed.
  As for that notched retaining washer thingy I use the same method, MCRider. When making further adjustments after riding a bit I slip a screwdriver into one of the notches and bang with a hammer, not pretty I know ;) :)
« Reply #3 on: December 17, 2008, 02:05:33 PM »
Oh yes I wasn't thinking about the top chrome nut.
And yes that's how I make my "final" adjustment as well.   :P
Offline Jakoba
« Reply #4 on: December 17, 2008, 04:49:11 PM »
Awesome, thanks guys.
Jako
Jako
Member #4500
Offline coyotecowboy
  • Easily Distracted
    • American Legion Riders Post 69 Medicine Lodge, Ks
« Reply #5 on: December 17, 2008, 05:06:52 PM »
Just for arguements sake, 50 ft/lb is about what most people can pull with a wrench or a standard-length half-inch drive rachet.  So just good and tight with a breakover should get it.  Don't go crazy with it, you might want to get it off again someday ;)
The adventure begins when things stop going as planned - Glen Heggstad
http://www.alrpost69.com/
Sunrise Orange 750 K2
1981 Husqvarna 430 XC, "Inga"
