Author Topic: Marvellous engine product?  (Read 4815 times)
Offline Kalamazoo
« on: December 18, 2008, 07:50:51 PM »
Anyone know anything about a product called Marvellous? Not sure if thats how you spell it.
My father mentioned it, I guess it's supposed to help free up valves, lube the engine, and make it run better.
Said he used it in his air planes, and tractors, (back in the 60's and 70's) and he said it would probably work for my bike?
Anyone know anything about this?
Is it even still around?
Or a product of similar traits?
M.R.
Offline stresssolutions
  • 4 years on a motorcycle, Time Flies!
  • 03 RoadStar, I miss my Honda
    • bloggy thoughts
Re: Marvellous engine product?
« Reply #1 on: December 18, 2008, 07:57:13 PM »
Could be Marvel's Mystery Oil.  I use it for lubing stuff, comes in spray, squirt, and other containers.
Enjoying life, one day at a time.
« Reply #2 on: December 18, 2008, 07:57:56 PM »
Never heard of it, probably American like STP or Wynns.
If it contains anti friction properties it's not good for Motorcycle engines with the clutch running in the same oil that lubes the rest of the motor, it makes them slip.
Sam. ;)
Offline Kalamazoo
« Reply #3 on: December 18, 2008, 08:15:26 PM »
ah, Marvel's mystery oil, thats most likely it.  haha, he's getting old, and memory isn't the best anymore, plus he hasnt used it since the 60's. At least he was pretty close on the name.
As I recall he said it would be added to the gas, not the oil.
Would that still cause in some way, the clutch to slip?  I would think it wouldn't have any effect on the clutch.
M.R.
« Reply #4 on: December 18, 2008, 08:32:21 PM »
Not if it's a fuel additive.
Sam. ;)
Offline Kalamazoo
« Reply #5 on: December 18, 2008, 08:34:42 PM »
Thanks!
Now I just gotta go buy some and see if it does any good.
M.R.
Offline 333
  • Time for change
« Reply #6 on: December 18, 2008, 08:41:53 PM »
My Dad used to make a "cocktail" with Marvel, and something else, and pour it down the carb of the car.  He'd come close to choking it out once or twice, then dump the rest down and choke the engine out.  It would fill the neighborhood with blue/grey smoke.  I was afraid the fire department would come a runnin'.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Mach-5(50)
    • ryan barr photography
« Reply #7 on: December 18, 2008, 08:42:35 PM »
marvel's mystery oil can be ran in either fuel or oil. in fact, it is great for diesel engines, since most of the sulfur has been removed from the diesel fuel. it does work as a friction modifier in engine oil, but samcr750 makes a good point.
it does work great as a penetrating oil, so if you have a stuck motor or valves, pouring some in and letting it sit for a few days it will likely come free.
marvel may also be known as a blending agent. there is another product from hydrotex called essentialube that is along the same lines. if you put a screw driver, or other metal object in a shallow container the essentialube will actually wick up the screw driver. pretty amazing product. like marvel it has too many uses to list.
aorta got onto another tangent there, but i hope it helps someone eventually.
later,
ryan
The more adults I meet, the more I want to help kids.
i used to be drunk and dirty,
now i am clean and sober.
http://www.ryanbarrphotography.com
« Reply #8 on: December 18, 2008, 08:45:15 PM »
I haven't used it, (Like Sammy, I'm not a native) but I've only seen good things about it on this site. Do a search under "Marvel's Mystery Oil" and you'll probably find heaps of info. Cheers, Terry. ;D
« Reply #9 on: December 18, 2008, 08:49:32 PM »
I can't say I have seen it over here in the UK but Wynns and STP made the same sort of stuff, and we also had a brand called RedX.
Just about every gas station had a RedX dispenser, for every gallon you put in the tank, you would get X amount of RedX.
In the early 70s I was sponsored by Wynns and was invited to a big demonstration of their products in Manchester.
I can honestly say that all their products did exactly what they were designed to do.
Sam. ;)
Offline mrbreeze
  • Not your average
« Reply #10 on: December 18, 2008, 08:51:57 PM »
It has been around forever.As already said.....I wouldn't recommend it in anything with a wet clutch.If you use it to free up an engine....change the oil before running it.As far as top end cleaning.....I would use Seafoam instead of Marvel.
MEMBER # 257
Offline Kalamazoo
« Reply #11 on: December 18, 2008, 09:12:39 PM »
I think first I'm just going to try it as a fuel additive, see what that does, see if there is any big improvments.
Says it can also help clear carbs when used as a fuel additive on their website
We'll see what happens.
M.R.
Offline Steve F
« Reply #12 on: December 19, 2008, 04:18:56 AM »
Here's their website:
http://www.marvelmysteryoil.com/
njoy  :D
Offline 547
« Reply #13 on: December 19, 2008, 09:15:41 AM »
when i bought my bike i took out the plugs and poured a small amount in each one and let it sit for a few days.
worked like a charm. bought it at auto zone. i use it as a fuel and oil additive but only because the website suggests it.
but i am not going to swear by that.
j-
Offline Kalamazoo
« Reply #14 on: December 19, 2008, 09:23:37 AM »
Thanks for the info!
We don't have an autozone here but I'm hoping Napa auto parts will carry it, I'm assuming they will.
M.R.
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #15 on: December 19, 2008, 09:28:46 AM »
I seem to remember Moto-Bunny had some helpful comments about it not too long ago.
edit: found something maybe useful. http://forums.sohc4.net/index.php?topic=23555.0
« Last Edit: December 19, 2008, 09:35:38 AM by Ecosse »
1974 CB550K
                                  Your 1%er name
Offline jhasewhite
  • my best vacation is your worst nightmare
« Reply #16 on: December 19, 2008, 10:14:02 AM »
I use it as a fuel additive and my engine loves it.
"old guys" with crusty leathers on crusty old bmw's seem to swear by it...
I would say its greatest power of mystery is lubricating the lower intake valve guides and carb slides preventing wear.
slow and steady does nothing.
Offline Ecosse
  • Member #4139
« Reply #17 on: December 19, 2008, 10:31:16 AM »
Just cruised the MMO forum and found a discussion regarding the product interest in the UK and other parts of the Olde Country. See this link and note post by 'misterchevy': http://www.marvelmysteryoil.com/index.php/forums/viewthread/18/
1974 CB550K
                                  Your 1%er name
Offline jhonsey
« Reply #18 on: December 19, 2008, 10:40:15 AM »
Ahhh, the hillbilly tuneup. It loosens stuck valves nicely. I have a couple of friends who use this procedure. If no Marvels around they use transmission fluid. One of them claims that Marvels is just scented transmission fluid anyway. I cannot confirm this though.
I do add it to my fuel though, seems to help the ol girl run nice.
Love is the feeling you get when you like someone as much as your motorcycle.
Offline Kalamazoo
« Reply #19 on: December 19, 2008, 11:12:41 AM »
All these great reviews! I gotta get some!
M.R.
Offline fmctm1sw
« Reply #20 on: December 19, 2008, 11:22:41 AM »
Sounds a lot like the last ime I cleaned out the throttle body on my '93 Dodge van with Seafoam...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline moham
  • .fnord.
« Reply #21 on: December 19, 2008, 11:25:00 AM »
I've even heard you can pour some on a plate with a crusty baguette and some grated Grano Padano for a nice antipasti...
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline cbr-eric
« Reply #22 on: December 19, 2008, 11:45:39 AM »
I use it in my bikes, 88 hurricane and an 82 cm250c and it worked good as a fuel additive. keeps my carbs cleaner and I had better luck not having problems in the middle of the summer. I recomend it :)
k8 project, a long way from done.....
Offline mrbreeze
  • Not your average
« Reply #23 on: December 19, 2008, 09:21:49 PM »
It probably says on the jug to use it in your oil but it won't say use it in a Honda motorcycle (or any engine with a wet clutch). Should work fine as a fuel additive or air tool lubricant.
MEMBER # 257
    • bloggy thoughts
« Reply #24 on: December 20, 2008, 07:27:38 PM »
If you location W.I. means wisconsin, you can get it at FleetFarm or any other farm supply store.  Or Menards.  Pretty common stuff, really.
