Author Topic: Is this set of 750 cases now trash?  (Read 6825 times)
Offline Brantley
  • Drano
« on: December 23, 2008, 11:00:21 AM »
I took these to my local machinist to have a crack welded and asked to have them bead blasted, thinking he would not blast the bearing journals and mating surfaces. Well, he did. Do I have anything to worry about? Can I clean the surfaces well and start reassembly or should I have 'em turned into Coke cams?
Offline dave400
  • Super Lamb Banana
Re: Is this set of 750 cases now trash?
« Reply #1 on: December 23, 2008, 11:38:17 AM »
Did the guy plug the oil holes before he cleaned the cases?
Offline Brantley
  • Drano
« Reply #2 on: December 23, 2008, 12:10:30 PM »
No.
Offline dave400
  • Super Lamb Banana
« Reply #3 on: December 23, 2008, 12:18:24 PM »
What a plonker!!!!!    make sure you clean all the oil journals if you decide they are not going to be the next batch if coke cans.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #4 on: December 23, 2008, 12:21:36 PM »
Fill up the bath tub ;)
Offline Geeto67
  • A grumpy
« Reply #5 on: December 23, 2008, 12:27:36 PM »
I didn't know coke had cams - is it a hot 3/4 street cam? ok kidding about your typos aside....
the bigger concern is that if the oil passages were not plugged before blasting you are going to have a lot of junk in there that once you reassemble your engine is going to be in your oil - ie your engine will not last very long at all.
As far as the finish is concerned, any machine shop can put a machined finish back on the areas necessary, in this case it is probably not as necessary with the main crank journals of the block as they are designed to hold a shell bearing in place. If I were you I would take the cases to a machine shop anyway just to make sure all the journals line up with each other.
Maintenance Matters Most
WHALEMAN
« Reply #6 on: December 23, 2008, 12:38:24 PM »
I believe what you are asking is after the bearing shell areas and the mating surfaces have been blasted can you fit a bearing that will have the correct clearance. I can only guess that not that much material was removed and I would try the bearing shell called for by the case and crank first and see how it plasticgauges. You can always order the next tighter bearing shell. Why on earth would someone blast the inside. As for cleaning the oil passages it will be hard but not impossible. Since I have been in and connected with the restaurant business for 30 years I wash cases in big commercial dishwashers and they come out perfect. I think you will be OK but wait for M Rieck's answer to be sure. Dan
Offline Brantley
  • Drano
« Reply #7 on: December 23, 2008, 12:39:12 PM »
So's I can play battleship and drop my new anchor?
Offline bunghole
« Reply #8 on: December 23, 2008, 12:41:53 PM »
I'm not sure if my guy plugged my oil passages, so I took it to the self serve car wash and blasted the hell out of it.  I also fully submerged it in a filled bathtub with soapy water and let it soak.  Then I rinsed at it and took the air gun to all the passages.  I also ran small brushes in anything I could.  I think you'll be alright, but it can never be too clean, so take your time.
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline Brantley
  • Drano
« Reply #9 on: December 23, 2008, 12:48:35 PM »
Yeah- Right now it's nicknamed "the Polar Bear"  :P
Pretty much. I really am not that worried about the oil passages as I sort of had the same idea 'bout a commercial dishwasher, and I'm meticulous about cleaning things that can't be seen. My house is a different story...
Offline Zig
« Reply #10 on: December 23, 2008, 02:46:59 PM »
Dishwasher?? Thats a great idea!! I just went in and measured ours, it fits!! Now if i can get her out of the house for a coupla hours......she is still pissed about the time i put the barrels from my triumph in the oven (baked enamel finish and still perfect).
« Reply #11 on: December 23, 2008, 03:42:23 PM »
Not taping off the upper mains does suck but it is not impossible to clean out. Rmove the main galley plug and blow it out with high pressure air. After that run plenty of soap and water down it and use a long round brush down it. There automative ones that work well. Blow it out a lot through the caps and main galley. If you can get a long wand for the air that would be great. It will be OK...... just repeat the process. Don't worry about the lower case....I have blasted those many times on many different engines. Don't worry....they are not scrap. ;)
« Reply #12 on: December 23, 2008, 07:21:19 PM »
If anything changed, I think the shells would be tighter, not looser, as the surface is raised.
Plastigage on assembly.
Offline Brantley
  • Drano
« Reply #13 on: December 24, 2008, 02:45:59 AM »
This is sorta what I wanted to hear. Is the main galley plug the one on the front with a flathead fitting or the one on the right where folks mount a pressure gauge? As I said I'm not really worried about cleaning the media from the oil passages; that WILL happen. I am more concerned with if the case halves and cylinder base (and other mating surfaces) will weep and if I can install main (and tranny) bearings on non machined surfaces.
« Reply #12 on: December 23, 2008, 10:21:19 pm »
One step ahead, 754. Plastigauged before the initial trip to the machinist and all was well within tolerance so I was planning on replacing the mains with the same color (I have to check my notes to be sure which). I really don't want to spend over a bill to find out I need a different size.
WHALEMAN
« Reply #14 on: December 24, 2008, 03:52:14 AM »
I believe he is referring to the plug on the left side of the big main tube where on the right side the gauges mount. If you take a long rod and run it in that passage from the right side and push on the shiny round plug on the left side it will push right out. Just an o-ring holding it in. Dan
« Reply #15 on: December 24, 2008, 10:02:15 AM »
So what i am saying is re-install the original bearings and pastiguage, BEFORE you order new ones, JUST IN CASE the clearance tightened up from surface being raised by blasting.
It would not  be a bad idea to tap that galley pug from the  e-start side, with a 6mm or 1/4 inch tap but not right thru, then can easily be removed to allow cleanout when engine is apart ...6mm means your engine cover bolts can be used to pull it out)
Offline Brantley
  • Drano
« Reply #16 on: December 24, 2008, 10:56:59 AM »
Roger that. Do they need to go back in their original positions? I have no way of telling now. (And some may have gone missing  ::)) So what you and MReick are telling me is I needn't worry about surfaces in question as long as everything's super clean and I measure carefully?
Another thought: Is there any advantage/ disadvantage in using threadlocker to install the tranny roller bearings (as is recommended in the Norton Commando gearbox)?
And Mreick, may I pm you when I get to the head work?
Sorry if I came off a bit pissy in my last post; I got off work really late and in a bad mood, but was still excited to see replies to my query. So thanks everyone.
« Reply #17 on: December 24, 2008, 11:25:13 AM »
I think you can get them back in by checking the numbers or by the color marking  of the shells.
You always should mark parts on diassembly, that way if your bearing were still good, and one set is backordered til 2010, you can reuse the old one..
I never heard of bearings turning in Honda cases.
 Remember if anything your bores are now tighter & grippier..
Offline Big Jay
    • CBRzone
« Reply #18 on: December 25, 2008, 07:16:04 PM »
Take all of the oil plugs out and take the cases to a transmission shop that rebuilds automatic transmissions, and have them wash them in their washing machine.
Jay
Offline Brantley
  • Drano
« Reply #19 on: December 26, 2008, 02:08:13 PM »
Jay
What kind of machine is this? I work in a bar and we have a commercial dishwasher for glasswear with rotary sprayers top and bottom and is large enough to lay one case half flat. The water temp is around 120º.
I planned on using that, the carwash, the tub, a black cat bone, and a mojo, too. Would it be worth dealing with another stranger that probably doesn't dig his job very much and probably gives less than a crap about my project? (Forgive the rant; I just got bent over replacing the tranny in my truck last month.)
If I may paraphrase Frank Zappa, "Hydrogen is not the most plentiful element in the universe- stupidity is."
It was kinda dumb of me to not mark each bearing location, but I had already plastigauged them and they were well within the service limit so I was going to replace them with the same color (yellow) because of minor scoring. What's really stupid is I trusted someone else NOT to be stupid.
« Reply #20 on: December 26, 2008, 02:20:29 PM »
The only problem I've seen is staining of the bare aluminum with the automotive washers/detergents. I'd be very careful putting those in any washing machine. If you are painting them no big deal.
« Last Edit: December 26, 2008, 03:31:18 PM by MRieck »
« Reply #21 on: December 26, 2008, 03:39:03 PM »
Yeah, what Mike said, most commercial dishwashing detergents are caustic soda based, and caustic and bare alloy are not good friends, and can even make your bare cases go black (don't ask me how I know, boohoo.........) I have heard of excellent results degreasing old painted cases in domestic dishwashers though, although I haven't had the balls to try it at home yet.
If you're cleaning after blasting though, I wouldn't do the dishwasher thing, there's no real advantage as your cases are already nice and clean. Like Derek and Mike suggested awhile back, dunk them in a tub of warm soapy water, and with a range of bore brushes and pipe cleaners, clean out every oilway, nook and cranny, (pipe cleaners for small threaded areas) flush everything out with a water jet, then blow everything out with compressed air, then repeat. You'll be gobsmacked at the amount of abrasive that ends up in the bottom of the tub! Cheers, Terry. ;D
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #22 on: December 26, 2008, 06:49:55 PM »
And your wife will love you al the more....mine did ;D
P.S Use a rubber mat for bottom of tub, don't ask me how I know ???
« Reply #23 on: December 26, 2008, 07:28:30 PM »
Jay did point you in the right direction,
ie,a place that is cleaning die-cast aluminum alloy parts.. so what they use will not harm your case.
« Reply #24 on: December 26, 2008, 07:31:42 PM »
It's the trisodium phosphate in dishwashing detergent that does not like aluminum.
