Author Topic: rust mort  (Read 2093 times)
Offline mrblasty
  • Expertly
rust mort
« on: September 29, 2005, 07:52:12 PM »
Any of You guys use a product called rust mort inside Your tanks?
I use it for treating rust before filler or skim coats, it converts rust back to metal with minimal surface prep aside from removing the scale.
Just curious
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline Bodi
Re: rust mort
« Reply #1 on: September 29, 2005, 08:27:45 PM »
This is just 45% phosphoric acid with a bit (1-5%) of isopropyl alcohol added for reasons unknown to me.
If it's cheap, fine. Behr concrete etch is stronger (higher acid content) and pretty cheap.
Offline Dennis
Re: rust mort
« Reply #2 on: September 29, 2005, 11:40:36 PM »
Never heard of rust mort.
Bodi -
What is Behr concrete etch? Do you know what type of acid is in it? Where do you purchase it?
Thanks!!
Offline Gordon
  • 750K1, 550K2
Re: rust mort
« Reply #3 on: September 29, 2005, 11:46:32 PM »
My guess is that the alcohol is added to absorb any latent moisture inside the tank that may be clinging to the rust.  Seems like a good idea to me.  That being said, it would be pretty easy to make your own homebrew version.
