Author Topic: Can of marbles in my engine!!!  (Read 1882 times)
Vagelis
« on: September 30, 2005, 12:05:47 AM »
Goodmorning gang,
 A couple of days ago I was going home after work, stopped at a red light and after idling for a couple of minutes the engine (CB400F) did a couple of 1,200 to 2,000 rpm jumps and died! I hit the start button and came back to life, or did she. At 1,200 (idle) it sounded like a "can of marbles" and ready to die, at 1,600 all was fine.
I went home took the carbs out and cleaned everything, checked the gas for water, nothing. Put them back hooked up the mercury columns, the vacum on #4 was at 46 the rest at 18! I synced them all checked the timing and took her for a ride.
The "can of marbles" (the noise sounds like it's coming from #2&3 carbs) is still there at 1,200 but with a steady idle, sync is fine on all carbs, at 1,400 rpm's everything is fine.
Any ideas?
One more thing I noticed that the #4 column on my sync thingy when it's hooked up has air bubbles! It's 15 years now since I bought it, should I change the mercury?What gives?
Thanks for the help, Vagelis.
Offline Chris Liston
Re: Can of marbles in my engine!!!
« Reply #1 on: September 30, 2005, 01:03:51 AM »
how about a valve adjustmant.
1976 CB550F Cafe in progress
« Reply #2 on: September 30, 2005, 06:10:34 AM »
Check cam chain sometimes those tensioner blades will snap
eldar
« Reply #3 on: September 30, 2005, 07:22:06 AM »
On a problem like this, I would look at mechanical before carburation issues.
Check the valves and even pull out the tensioner and visually inspect it.
Guess I am just backing what the others said.
Vagelis
« Reply #4 on: October 03, 2005, 12:13:56 AM »
Saturday morning I checked the cam chain & valve lash. Everything was like it should be. The "marbles" were still around. Sunday I went for a 2 hour ride on the highway, when I stopped some of the "marbles" had disapeared! On the way back I took the long and winding rode through the mountains, pushing the red line alot. On a straight hitting the reds the motor sturted to stutter, it spit a couple of times through the carbs, and went back to normal!! The marbles are gone at idle!!! Any ideas?
Offline dusterdude
« Reply #5 on: October 03, 2005, 05:57:06 AM »
sounds like you picked up a little trash in your carbs and when they spit the stuff was spit out of the jet or wherever it was,of course i would feel better if carb guru bob would check me on this.hi bob,im back. :D
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
