Author Topic: Triumph clutch issue.  (Read 912 times)
Offline gerhed
« on: December 31, 2008, 11:26:30 AM »
--67 650
Always do clutch freeing ritual
--neutral, clutch in--kick it 'till the clutch is free-(engine stops turning over)
Machine starts easily, but tremendous knashing of gears when putting it into gear.
--eventually I believe I will break something in there.
Looking for a prescription that doesn't involve pulling off
the primary case and taking the clutch apart.
          83 XL600R in CB360 Frame
Re: Triumph clutch issue.
« Reply #1 on: January 01, 2009, 07:10:26 AM »
ER
(1) They all do that sir
(2) you gonna have to take the case off and make sure that the pressure plate is lifting "square"---adjust springs till it does---Good idea to check inner and oute splines are OK at same time.
Pick any answer and live with it
