Author Topic: CB750 K7 or K8 gas tank questions  (Read 991 times)
ev0lution7
« on: December 31, 2008, 11:00:07 PM »
anyone here know how to remove that screeen at the bottom of the K7 K8 gas tanks?? i have some sediment i'd like to remove with the bike it sitting idle for the winter and last time i had the tank off the the life of me i couldnt get all of it out?
KingCustomCycles.com
Re: CB750 K7 or K8 gas tank questions
« Reply #1 on: January 01, 2009, 02:43:02 AM »
I thread a tap into it lightly and then pull on it while rocking.
Offline void909
« Reply #2 on: January 01, 2009, 04:08:22 AM »
What screen. I have a k8 tank but ive never seen a screen.
knock with no answer
Offline TheHun
« Reply #3 on: January 01, 2009, 05:35:40 AM »
I tapped it and rocked just like the above post.
You should have a plastic like filter pressed in your line where the petcock is. If you flash a light in the tank you can see it hiding there. If you dont have one, I hope you have somekind of filter with your fuel line, it doesn't let through bigger contaminants
1978 Honda CB750-K
CBR F3 Coils
Kerker 4.1 Header w/ turn down
Maxi-Dwell Ignition
Foam Air Filter Pods
Superbike bars
Starter Delete
CARB CLEANING/REBUILD: http://www.wix.com/TheHun/CarbCleaning-Site
Not Running to Running, doing the work yourself= Priceless
ev0lution7
« Reply #4 on: January 02, 2009, 10:25:56 PM »
well i will try that if it breaks can i leave it out and just put in an IN-Line filter??
